Forum Topic - create shared mem in mpc85xx_attach, where to destroy the mem?: (8 Items)
I created a shared mem object by calling shm_open() in the function mpc85xx_attach() e.g.
 fd = shm_open( fileName, O_RDWR | O_CREAT, 0777 );
I wish to destroy this shared mem object when io-pkt-v4 exits for some reason (e.g. being slayed).
In which function should I call the function shm_unlink(fileName);
Thanks.
Re: create shared mem in mpc85xx_attach, where to destroy the mem?
You would do this in the mpc85xx_stop routine.
On 2012-08-06 5:39 PM, "Wen Xu" <community-noreply@qnx.com> wrote:
>Hi,
>Thanks.
>Networking Drivers
>http://community.qnx.com/sf/go/post94661
> >Hi,
> >Thanks.
Thanks. As suggested shm_unlink() is called in the function mpc85xx_stop().
However, after I issue the command "slay io-pkt-v4", this shared mem object is still accessible
from another process. Would you please suggest why the share mem object is not destroyed successfully?
e.g.
static void
mpc85xx_stop(struct ifnet *ifp, int disable)
if (disable)
The file will only be removed once all references to it have been removed,
so if another process has the filename open, it will only be removed once
that process releases it.
>> >Hi,
>> >Thanks.
>mpc85xx_stop().
>e.g.
>static void
>if (disable)
>Networking Drivers
>http://community.qnx.com/sf/go/post94676
Thanks. The problem is, the shr mem object is created/reads/writes  in io-pkt-v4 process.
The other process reads/write to the shr mem. When io-pkt-v4 is slayed or exits, I wish the mem object to be destroyed.
It's okay that the other process could no longer have access to the shr mem. Is there any way to achieve that?
I don't think so. There is a reference count for each open of the shared
memory object and it is only destroyed when the reference count is zero.
>>removed,
>>once
>io-pkt-v4 process.
>exits, I wish the mem object to be destroyed. It's okay that the other
>achieve that?
>Networking Drivers
>http://community.qnx.com/sf/go/post94681
Thanks.That's what I am thinking about. Is there anyway to get the reference count? Any API?
No, this is in the libc library.
>Networking Drivers
>http://community.qnx.com/sf/go/post94683
