using gdb on network shared library
08/02/2012 10:27 AM
post94594
I need to run gdb on a my shared library loaded by mount. I normally would start my driver like so:
mount -v -T io-pkt devnp-canpro_g.so -o baud=1000,port=0,board_index=0,verbose
but if I start gdb like this:
gdb --x ./gdbopts --args mount -vvv-T io-pkt devnp-canpro_g.so -o baud=1000,port=0,board_index=0,verbose
where gdbopts contains:
set solib-search-path /lib/dll
set auto-solib-add 1
And I set a breakpoint on my _attach etc entry point it never gets called before mount exits and the program ends
normally.
Any tips on how to debug my devnp-canpro_g.so?
I have been able to get it to load and debug using this:
gdb --x ./gdbopts --args io-pkt-v4 -v -dcanpro_g baud=1000,port=0,board_index=0,verbose
but a bug I am seeing does not show up with this method of starting.
Allan
