Forum Topic - io-pkt-v4-hc exit unexpected (crash):
Hi all,
I need your help finding out what could be the problems causing the io-pkt-v4-hc crash occationally when I issue a "
ifconfig en0 down" command on QNX 6.5.0. All clues are appreciated!
Some details of the setting up.(Please let me know if you need more information):
There are two QNX PCs(works as 1+1 backup). Each QNX PC has two NICs (en0 and en1); one of the two NIC (en1) on each PC
is used to connect with the other PC's en1 running mqueue with qnet protocol. The other NICs (en0) on each PC are
configured with the same MAC/IP addresses (one PC en0 is down and another PC en0 is up) to work as 1+1 backup. Both en0
are connected with a third PC to provide service. I am running rp-pppoe 3.20(built from source) server on both QNX PCs
and pppoe client on the third PC. I need to test hot swap between two QNX PCs  (basically, move the established pppoe
sessions from one PC to another without redial, both PCs have the same pppoe session information before moving).
It works well most of the time. After I "ifconfig en0 down" one PC and "ifconfig en0 up" another PC, the pppoe sessions
on the second PC take over by redoing the LCP negotiation automatically. But some time, when issuing the ifconfig en0
down on one PC and issuing the ifconfig en0 up on another(down is about 300ms earlier than the up command), the one
which ifconfig en0 down is issued reports "bad file descriptor" for the socket or "no such process" errors. And the io-
pkt-v4-hc disappeared from the "ps -A" list. When I checked by pidin mem, neither io-pkt-v4-hc nor devn-rtl.so/devnp-
shim.so/devn-rtl.so/lsm-qnet.so exist. nicinfo is empty. ifconfig list is empty too. I have to reload all NIC drivers or
 restart the OS to recover this.
It does not happend all the time, some time it happens if I swap once; some time I need to do swap more than 100 times
to make it happen.
Thanks a lot in advance!
Yours
Jay
Re: io-pkt-v4-hc exit unexpected (crash)
Please can you try this with the latest driver in 6.5.0 SP1, available on
our web site.
On 12-06-21 7:14 AM, "y cheng" <community-noreply@qnx.com> wrote:
>Hi all,
>io-pkt-v4-hc crash occationally when I issue a "ifconfig en0 down"
>information):
>and en1); one of the two NIC (en1) on each PC is used to connect with the
>each PC are configured with the same MAC/IP addresses (one PC en0 is down
>and another PC en0 is up) to work as 1+1 backup. Both en0 are connected
>source) server on both QNX PCs and pppoe client on the third PC. I need
>pppoe sessions from one PC to another without redial, both PCs have the
>"ifconfig en0 up" another PC, the pppoe sessions on the second PC take
>issuing the ifconfig en0 down on one PC and issuing the ifconfig en0 up
>socket or "no such process" errors. And the io-pkt-v4-hc disappeared from
>devn-rtl.so/devnp-shim.so/devn-rtl.so/lsm-qnet.so exist. nicinfo is
>some time I need to do swap more than 100 times to make it happen.
>Yours
>Jay
>Networking Drivers
>http://community.qnx.com/sf/go/post93804
The SP1 seems fixed the problem perfectly! (although I don't know what was the problem;p)
My script runs whole night for more than 600 times now and all NICs are still alive working hard.
Many many thanks!
Yours
Jay
> our web site.
> >Hi all,
> >information):
> >Yours
> >Jay
> >Networking Drivers
