Forum Topic - Setting an IPv6 device/interface using ipconfig & route commands:
I'm trying to configure a device/interface manually using ipconfig and route.
I have the following parameters:
- IPv6 address
- Prefix len
- Default IPv6 gateway
- device name
I'm using the following syntax
ipconfig <device name> inet6 <ip_address> <prefix_len> up
route –v add –inet6 :: <gateway_address>%<device_name>
I can see that the ipconfing is being set, and the entries are set into the routing table, but I think that there's
something incomplete with this syntax, since I can't open sockets and connect to other IPv6's... The network
configuration has been tested, and I should be able to make IPv6 socket connections.
Is there anything I should add to the two commands I'm invoking?
Re: Setting an IPv6 device/interface using ipconfig & route commands
I think that "should" work. (Assuming you meant ifconfig not ipconfig
right?)
Can you try ping6 -n to the default gateway%device? What does ndp -c say
while you ping? What does ndp -c say?
Cheers!
/P
On 11-09-06 4:01 PM, "David Arinzon" <community-noreply@qnx.com> wrote:
>Hi,
>route.
>- IPv6 address
>- Prefix len
>- device name
>route ­v add ­inet6 :: <gateway_address>%<device_name>
>the routing table, but I think that there's something incomplete with
>The network configuration has been tested, and I should be able to make
>Thanks
>Networking Drivers
>http://community.qnx.com/sf/go/post88663
I've ran NDP -a:
# ndp -a
Neighbor                        Linklayer Address  Netif Expire    St Flgs Prbs
2002:c023:9c17:d08:e86d:e1d8:8c73:a9fc (incomplete) msm0 permanent R
fe80::202:ff:fe00:1%msm0        (incomplete)        msm0 permanent R
fe80::b093:fd2:ecd6:a7e1%msm0   02:50:f3:00:00:00   msm0 22s       R  R
I would like to note that I've used rtsold and auto configuration before, and it worked OK, but now when I try
configuring by myself [using ifconfig + route] it doesn't.
I'm attaching a tcpdump from when the it tries to connect on a socket.
Additionally, when comparing the routing tables between the working and non-working versions, I can see that the address
 of the gateway is mapped to 00:00:00:00:00:00
fe80::a02d:adc:6a8d:ca06%msm0      00:00:00:00:00:00
While when I configure by myself, it's mapped to something different
fe80::a02d:adc:6a8d:ca06%msm0      link#3
I'm pretty sure there's something wrong with my syntax, and I forgot to mention some flags.
Your help will be much appreciated!
Attachment: Text tcpdump.txt 2.27 KB
