Forum Topic - Trouble with devnp-i82544 in QNX 6.5.0:
I'm having trouble mounting the devnp-i82544 driver in QNX 6.5.0.
MID-1# ls /alt
ls: No such file or directory (/alt)
MID-1# io-pkt-v4-hc -i1 -ptcpip prefix=/alt
MID-1# mount -Tio-pkt1 -opci=0,vid=0x8086,did=0x1076,priority=32,mac=0082FFBFFFA F devnp-i82544.so
MID-1# SOCK=/alt ifconfig
ifconfig: getifaddrs: Address family not supported by protocol family
Any idea what's going on here? The commands all seem pretty straightforward. FWIW, the legacy devn-i82544 driver mounts
just fine.
If you're wondering, yes, the specified device does exist.
MID-1# pci
PCI version    = 2.10
Device ID      = 3582h,  82852/855GM Integrated Graphics Device
PCI index      = 0h
BAR - 0 [Mem]  = f0000000h enabled
BAR - 1 [Mem]  = ffa80000h enabled
BAR - 2 [I/O]  = ec00h enabled
PCI Int Pin    = INT A
Interrupt line = 9
CPU Interrupt  = 9h
Class          = Display (Other)
PCI index      = 1h
BAR - 0 [Mem]  = e8000000h enabled
BAR - 1 [Mem]  = ffa00000h enabled
PCI Int Pin    = NC
Interrupt line = 0
CPU Interrupt  = 0h
Class          = Mass Storage (IDE)
Device ID      = 24cbh,  82801DB (ICH4) IDE Controller
PCI index      = 0h
BAR - 0 [I/O]  = 0h enabled
BAR - 1 [I/O]  = 0h enabled
BAR - 2 [I/O]  = 0h enabled
BAR - 3 [I/O]  = 0h enabled
BAR - 4 [I/O]  = fc00h enabled
BAR - 5 [Mem]  = ffeffc00h enabled
PCI Int Pin    = INT A
Interrupt line = 0
CPU Interrupt  = 0h
Class          = Multimedia (Audio)
Device ID      = 24c5h,  82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller
PCI index      = 0h
BAR - 0 [I/O]  = e800h enabled
BAR - 1 [I/O]  = e400h enabled
BAR - 2 [Mem]  = ff9ffc00h enabled
BAR - 3 [Mem]  = ff9ff800h enabled
PCI Int Pin    = INT B
Interrupt line = 5
CPU Interrupt  = 5h
Class          = Multimedia (Other)
Vendor ID      = 10b5h, PLX Technology, Inc.
Device ID      = 9030h,  PCI9030 32-bit 33MHz PCI <-> IOBus Bridge
PCI index      = 0h
BAR - 0 [Mem]  = ff7ffc00h enabled
BAR - 2 [Mem]  = ff600000h enabled
BAR - 3 [Mem]  = ff500000h enabled
PCI Int Pin    = INT A
Interrupt line = 9
CPU Interrupt  = 9h
Class          = Network (Ethernet)
Device ID      = 1209h,  8255xER/82551IT Fast Ethernet Controller
PCI index      = 0h
BAR - 0 [Mem]  = ff7fe000h enabled
BAR - 1 [I/O]  = dc00h enabled
BAR - 2 [Mem]  = ff7c0000h enabled
PCI Int Pin    = INT A
Interrupt line = 7
CPU Interrupt  = 7h
Device ID      = 1076h,  82541GI Gigabit Ethernet Controller
PCI index      = 0h
BAR - 0 [Mem]  = ff7a0000h enabled
BAR - 2 [I/O]  = d800h enabled
PCI Int Pin    = INT A
Interrupt line = 6
CPU Interrupt  = 6h
Thanks.
Mark
Re: Trouble with devnp-i82544 in QNX 6.5.0
You should be using the devnp-e1000 driver under 6.5.0.
>MID-1# ls /alt
>devnp-i82544.so
>straightforward. FWIW, the legacy devn-i82544 driver mounts just fine.
>MID-1# pci
>PCI version    = 2.10
>PCI index      = 0h
>PCI Int Pin    = INT A
>Interrupt line = 9
>CPU Interrupt  = 9h
>PCI index      = 1h
>PCI Int Pin    = NC
>Interrupt line = 0
>CPU Interrupt  = 0h
>PCI index      = 0h
>PCI Int Pin    = INT A
>Interrupt line = 0
>CPU Interrupt  = 0h
>Controller
>PCI index      = 0h
>PCI Int Pin    = INT B
>Interrupt line = 5
>CPU Interrupt  = 5h
>PCI index      = 0h
>PCI Int Pin    = INT A
>Interrupt line = 9
>CPU Interrupt  = 9h
>PCI index      = 0h
>PCI Int Pin    = INT A
>Interrupt line = 7
>CPU Interrupt  = 7h
>PCI index      = 0h
>PCI Int Pin    = INT A
>Interrupt line = 6
>CPU Interrupt  = 6h
>Thanks.
>Mark
>Networking Drivers
>http://community.qnx.com/sf/go/post88611
