Re: Does "ifconfig tsec0 create" command work
03/31/2011 9:51 AM
post84470
On Thu, Mar 31, 2011 at 09:46:20AM -0400, Rama Krishna wrote:
> We have mpc85xx card load with QNX 6.4.1 version. We have mounted a
> packet-filter on tsec0 interface. In pf module "PFIL_IFNET_DETACH"
> event will be caught to remove the pfil hooks added. To generate
> "PFIL_IFNET_DETACH" event the "ifconfig tsec0 destroy" command is
> executed.
> After that we wanted to mount the packet-filter again without restarting
> the card. When we tried "ifconfig tseco create" command to create tsec0
> interface it is failing with the following error.
> ifconfig: SIOCIFCREATE: Invalid argument
> Please let us know if we miss anything here to create tsec0 interface.
# mount -T io-pkt /lib/dll/devnp-mpc85xx.so
You can only 'ifconfig create' types listed in 'ifconfig -C'.
