Forum Topic - Problem with two network drivers: (2 Items)
Hi all,
I am writing a wireless network driver (with io-net framework: not io-pkt framework) where in i am able to register my
driver with io-net and i am getting interface name as en0 in /dev/io-net.
If i load one more network driver with the help of io-net, i am not able to see 2 interfaces (en0, en1) in /dev/io-net.
Information displayed by ifconfig depicts recently loaded driver with only one interface en0(That means it is over
writing interface created by previously loaded driver)
Where am i going wrong?
Plz help me in this regard
Thanks & Regards
Arun L Hegde
Re: Problem with two network drivers
On Thu, Jan 17, 2008 at 08:05:34AM -0500, Arun Hegde wrote:
> Hi all,
. Information displayed by ifconfig depicts recently loaded driver with only one interface en0(That means it is over
I doubt it's overwriting the existing one, rather it's
probably failing the second attempt.  Check the return code
from ion->reg() for -1 and post the errno (if it's failing).
