RE: Problem with devn-tigon3.so
12/27/2007 11:43 PM
post3996
----Original Message----
Sent: Friday, December 28, 2007 12:33 AM
To: drivers-networking
Subject: Re: Problem with devn-tigon3.so
>> Hi,
>> I'm trying to get a PC (running QNX 6.3.2) on the network, using the
>> PCI based Broadcom 5782 NIC. Here is the card information as
>> provided by "pci" command:
>> Class = Network (Ethernet)
>> Vendor ID = 14e4h, Broadcom Corporation
>> Device ID = 1696h, NetXtreme BCM5782 Gigabit Ethernet
>> PCI Index = 0h
>> PCI Mem Address = fc500000h enabled
>> PCI Int Pin = INT A
>> Interrupt Line = 5
>> CPU Interrupt = 5h
>> The network card works fine when booted using Linux & using tg3
>> (linux) driver . However, since the QNX system did not
automatically
>> start a driver, I tried starting the trigon3 driver manually:
>> io-net -d tigon3 verbose -p tcpip
>> io-net -d tigon3 verbose=4 -p tcpip
>> io-net -d tigon3 verbose -p tcpip &
>> io-net -d tigon3 verbose=4 -p tcpip &
>> For each of the above commands, I observe the same behaviour - the
>> ethernet card is not detected ("ifconfig" just shows me the loopback
>> device lo0, although "ps -eaf" shows io-net (with tigon3 driver) is
>> still running). There is no output on the console or in sloginfo
>> about any anything related to devn- tigon3.so.
>> Please note that I did not build any new driver. I think io-net is
>> automatically using the one available in /lib/dll.
>> Am I missing something here? Is my network card supported?
>> Thanks,
>> Rajat
> Try this, see if it works.
> # slay -f io-net
> # io-net -d tigon3 vid=0x14e4,did=0x1696 -p tcpip
> make sure there is no space around the comma in vid/did option.
Thanks, it worked.
Rajat
