Re: Broadcom Driver for QNX 6.3.0
09/17/2010 4:05 PM
post67779
Looking at the 6.3.0 source for the tigon3 driver, this device is supported.
Is there anything logged in sloginfo?
On 10-09-17 1:57 PM, "Mark Dornbush" <community-noreply@qnx.com> wrote:
> We are using QNX 6.3.0 with no service packs and it seems the Broadcom 57XX
> network card in our laptop isn't supported. Has there been a driver update
> for this NIC?
> Alternatively, would it be possible to get a 3COM PCMCIA network card to work?
> This is the pci -v output for the Broadcom NIC.
> Class = Network (Ethernet)
> Vendor ID = 14e4h, Broadcom Corporation
> Device ID = 1600h, Unknown Unknown
> PCI index = 0h
> Class Codes = 020000h
> Revision ID = 2h
> Bus number = 4
> Device number = 0
> Function num = 0
> Status Reg = 10h
> Command Reg = 106h
> I/O space access disabled
> Memory space access enabled
> Bus Master enabled
> Special Cycle operations ignored
> Memory Write and Invalidate disabled
> Palette Snooping disabled
> Parity Checking disabled
> Data/Address stepping disabled
> SERR# driver disabled
> Fast back-to-back transactions to different agents enabled
> Header type = 0h Single-function
> BIST = 0h Build-in-self-test not supported
> Latency Timer = 0h
> Cache Line Size= 10h un-cacheable
> PCI Mem Address = ecef0000h 64bit length 65536 enabled
> CardBus CIS Pointer = 7h
> Subsystem Vendor ID = 1028h
> Subsystem ID = 1c8h
> Max Lat = 0ns
> Min Gnt = 0ns
> PCI Int Pin = INT A
> Interrupt line = 5
> CPU Interrupt = 5h
> Capabilities Pointer = 48h
> Capability ID = 1h
> Capabilities = c002h - 64002100h
> Capability ID = 3h
> Capabilities = 0h - 85200080h
> Capability ID = 5h
> Capabilities = 86h - 84cfce0h
> Capability ID = 10h
> Capabilities = 1h - 5040fa2h
> Device Dependent Registers:
> 0x40: 00 00 00 00 00 00 00 00 01 50 02 c0 00 21 00 64
> 0x50: 03 58 00 00 80 00 20 85 05 d0 86 00 e0 fc 4c 08
> 0x60: 05 10 2c 00 06 7e 00 00 00 00 02 60 00 00 00 00
> 0x70: 12 12 00 00 20 00 00 00 50 00 00 00 00 00 00 00
> 0x80: 00 00 00 00 00 00 00 00 00 00 00 00 fe 10 08 04
> 0x90: 21 ba 00 00 00 00 00 00 00 00 00 00 00 00 00 00
> 0xA0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
> 0xB0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
> 0xC0: 00 00 00 00 00 00 00 00 0e 00 00 00 00 00 00 00
> 0xD0: 10 00 01 00 a2 0f 04 05 00 20 1b 00 11 5c 03 00
> 0xE0: 42 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
> 0xF0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
> Thanks
> Networking Drivers
> http://community.qnx.com/sf/go/post67761
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
