Forum Topic - eide_identify_devices:
Need help.
I use qnx-.6.5.0 on ECX810 motherboard (Tolapai http://www.ibase-i.com.tw/ecx810.htm )  with the network card (ep80579).
 Same problem is listed in this topic http://community.qnx.com/sf/discussion/do/listPosts/projects.networking/discussion
.drivers.topc13934?pageSize=-1#post_post55855
I try to find a solution when I am analyzing source code of devnp-i80579.so  driver. I made the dump of memory when is
GCU handle and I saw the GCU device is in the  Volari Z11 videocard mamory area. So I made decision that Marvell 88e1145
 is not recognized before starting of the devnp-i80579.so driver.
Could you help me detect marvell 88e1145 chip correctly.
PS: the corresponding parts of sloginfo
Aug  30 11:21:36    2     5     0 libcam.so (Mar 12 2010 01:14:51) bver 6040206
Aug  30 11:21:36    2    19     0 eide_identify_devices: Intel EP80579 SATA vid 0x8086, did 0x5028, class 0x1018a rev 1,
 busno 0, dfunc fa
Aug  30 11:21:36    2    19     0 eide_identify_devices: cmd_addr 0x1f0, cntl_addr 0x3f4, irq 0xe, chnl 0, udma 6, mdma
2, sdma 0, pio 4
Aug  30 11:21:36    2    19     0 eide_identify_devices: probing dev 0 status 50, error 0
Aug  30 11:21:36    2    19     0 eide_identify_devices: probing dev 1 status 0, error 0
Aug  30 11:21:36    2    19     0 eide_parse_identify:  IDENTIFY DRIVE CMD cksum failure 192
Aug  30 11:21:36    2    19     0 eide_display_identify: mdl WDC WD2500JS-23MHB0 sn WD-WCANK3600852 fw 03.01C03 tid 0,
cable 40, max udma 6, cur udma 5, max mdma 2, cur mdma 0, max sdma -1, cur sdma -1, pio 4, mblk 16
Aug  30 11:21:36    2    19     0 eide_init_devices: WDC WD2500JS-23MHB0 path 0, tid 0, udma 5, mdma 2, sdma -1, pio 4,
mblk 16
 busno 0, dfunc fa
Aug  30 11:21:36    2    19     0 eide_identify_devices: cmd_addr 0x170, cntl_addr 0x374, irq 0xf, chnl 1, udma 6, mdma
2, sdma 0, pio 4
