Re: QNX 6.4.0 has bug with RTL8111C?
05/25/2010 6:16 AM
post55457
Well, I can get the reply from the robot when I use boot loader: qnxbasema but not qnxbasesmp..
So different boot loader affect the hardware? Can anyone give me a short explaination?
Thank you!
05/25/2010 8:48 AM
post55466
It doesn't look as though the link is being established. You can prove this
by running 'nicinfo' and looking at the "Current Operation Rate" line. If
you boot the non-smp image, is the link established?
On 10-05-24 10:30 AM, "Jason Yee" <community-noreply@qnx.com> wrote:
> I just install QNX6.4.0 with my new PC and the network card is RTL8111C, the
> card was found and when I try ifconfig, the result is
> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 33192
> inet 127.0.0.1 netmask 0xff000000
> en0: flags=80008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,SHIM> mtu 1500
> capabilities=7<IP4CSUM,TCP4CSUM,UDP4CSUM>
> enabled=0
> address: 90:e6:ba:53:41:78
> inet 192.168.0.16 netmask 0xffffff00 broadcast 192.168.0.255
> and I can ping 127.0.0.1.
> But when I connect it to a robot controller with IP 192.168.0.254, the I
> cannot get through with ping 192.168.0.254. it said the host is down, but I
> can receive the reply from the robot controller when use my old PC (network
> card is intel***).
> In addition, if I use command ifconfig en0 IP4CSUM TCP4CSUM UDP4CSUM, and ping
> again then the pc died.
> What the problem is ? actually, I received the reply from the robot yesterday
> with ping, but today I try ifconfig en0 IP4CSUM TCP4CSUM UDP4CSUM first, then
> I can not connect to the robot controller any more.
> Please help, many thanks in advance!
> Jason
> Networking Drivers
> http://community.qnx.com/sf/go/post55433
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
