05/17/2010 3:07 PM
post54888
I'm porting an application from LINUX to QNX that uses CDC ECM over USB. The Linux Kernel supported this by linking a
network device to the USB device.
So far, I have created a rudimentary USB CDC ECM driver that detects if a ECM device is plugged in and obtains the Data
interfaces and endpoints, etc. The USB DDK seems to make all this work fine.
What I am quite unclear about is how to link this to a network device. So far I have come to the conclusion that I need
to
a) Create a network device driver that receives the packets from the stack and passes them onto the USB driver which
writes them to ECM data channel (In itself an altsetting.)
b) Create the reverse mechanism, a means of the USB driver sending received packets on the ECM.
c) Some mechanism to create the (enX) device...
So far I guess I need to be able to write a driver that I can start up with io-pkt and access using a different socket
using SOCK.
What I am unclear about is the interface required to write the driver - there is a document (Apparently) with the source
, but I am an unable to download the source - I'm not sure what permissions I need.
Is what I am trying to do crazy? Is there a way of obtaining the description of the interface that is required?
Will I be able to connect a USB driver to the network driver and tell it to create a network interface that I can then
use?
Any help would be appreciated...
