Problem: Intel 82567LM doesn't work with jumbo frames
03/01/2010 4:42 AM
post48485
Hello.
I like to use a on board Intel 82567LM NIC with jumbo frames under QNX 6.4.1, but it doesn't work.
The nicinfo returned many squelch test errors on this interface.
Intel says this NIC supports 9k jumbo frames.
Device-ID of the NIC is 10de and it starts with the e1000.so driver.
I have configured the NIC as follows:
ifconfig wm0 ip4csum tcp4csum udp4csum
ifconfig wm0 mtu 8100
ifconfig wm0 192.168.101.100/24 up
It works if I choice a mtu of 1500 but not with 8100.
What can be the problem?
best regards,
Sven Fieske
RE: Problem: Intel 82567LM doesn't work with jumbo frames
03/01/2010 9:50 AM
post48509
My bad. I hi-jacked that counter for rx fifo overruns.
Regardless, you are seeing excessive bus latency which
is causing you to lose rxd packets. If possible, you
should get rid of those.
Sure does. However jumbo frames are not part of
the IEEE (or any other) standard, so support for it
is spotty.
Because I like jumbo frames (eg for high throughput and
benchmarks) the now-deprecated devnp-i82544.so had support
for jumbo frames. However, I am not sure if the new
devnp-e1000.so supports them or not, which is reasonable,
because like I said, jumbo frames are not part of any
standard and hence is not required. Heck, people don't
even agree what a jumbo frame is.
Hugh?
aboyd
Re: Problem: Intel 82567LM doesn't work with jumbo frames
03/01/2010 10:04 AM
post48511
The driver should support jumbo frames, but it hasn't been tested.
> is spotty.
> Hugh?
> aboyd
> Networking Drivers
> http://community.qnx.com/sf/go/post48509
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
03/01/2010 10:14 AM
post48513
If i run my jumbo frame app with a Intel 82574L NIC (10d3), it works very fine.
What can I do now?
I must use jumbo frames!
03/01/2010 10:19 AM
post48514
Two options come to mind:
1) download the source and fix it. It's probably not
a big change, if devnp-e1000.so supports jumbo frames
for other DID's.
2) create a PR and assign it to Bert for prioritization.
aboyd
Re: RE: Problem: Intel 82567LM doesn't work with jumbo frames
03/03/2010 3:43 AM
post48683
03/01/2010 11:19 AM
post48526
> From: Hugh Brown [mailto:community-noreply@qnx.com]
> Sent: Monday, March 01, 2010 10:05 AM
> To: drivers-networking
> Subject: Re: Problem: Intel 82567LM doesn't work with jumbo frames
Works for us.
> > is spotty.
> > Hugh?
> > aboyd
> > Networking Drivers
> K2M 1W8
> Networking Drivers
> http://community.qnx.com/sf/go/post48511
04/27/2010 10:39 AM
post52896
yes, it works but look at the latency. at the moment i'm doing network performance measurements and i get worst case
latencies between 1-5 seconds if you send UDP packets which are around 60kbytes in size.
a smaller MTU works way better in terms of reliability, here you get constant and reasonable latencies.
i think the stack or driver has massive problems with frames greater than the standard size of 1500 bytes, while the
packet-size itself is not the problem.
04/28/2010 4:08 AM
post52967
I just tested the devnp-e1000.so driver instead of the devnp-i82544.so and got way better results with jumboframes (9000
bytes).
it seems that this is a device driver related problem.
my latencies drastically decrease when i want to transmit UDP packets of the size of 64000 bytes when i use a MTU of
9000.
unlike the devnp-i82544.so device driver the devnp-e1000.so seems to handle jumboframes very well.
btw.: I'm using a 82572EI chipset
RE: RE: Problem: Intel 82567LM doesn't work with jumbo frames
04/28/2010 8:14 AM
post52977
> From: Philipp Lutz [mailto:community-noreply@qnx.com]
> Sent: Wednesday, April 28, 2010 4:09 AM
> Subject: Re: RE: Problem: Intel 82567LM doesn't work with jumbo frames
> and got way better results with jumboframes (9000 bytes).
> of the size of 64000 bytes when i use a MTU of 9000.
Hum? A UDP packet of 64000? I though UDP packet always had to be smaller than the MTU?
> Networking Drivers
> http://community.qnx.com/sf/go/post52967
04/28/2010 9:18 AM
post52991
The UDP datagram size is limited by: the 16bit UDP length field in the
UDP header and the maximum size of an IP datagram and any implementation
limits, less the size of the IP header and any options (IPv4 case) or
extension headers (IPv6 case).
If the (P)MTU is smaller, then the packet will simply be fragmented at
the IP layer.
/P
04/28/2010 10:01 AM
post53003
> From: Patrik Lahti [mailto:community-noreply@qnx.com]
> Sent: Wednesday, April 28, 2010 9:18 AM
> implementation
> the IP layer.
What happen on the receiving end?
> /P
> Networking Drivers
> http://community.qnx.com/sf/go/post52991
04/28/2010 10:18 AM
post53006
>> implementation
>> the IP layer.
Not sure if this is what you're asking, but they get reassembled at the
IP layer and passed up UDP and queued on the socket (if there is one)...
/P
04/28/2010 8:32 AM
post52981
Good news! Thanks for the update.
> Networking Drivers
K2M 1W8
04/30/2010 6:16 AM
post53276
I tested again. my setup was slightly different compared to the last time. for the latency measurements this time I used
a dedicated network interface with a point-to-point connection and separate stacks.
now the devnp-i82544.so shows consistent and reasonable performance even when jumbo-frames have been used, though the
devnp-e1000.so provided far better performance in every respect.
here are some provided requirements for my tests:
- normal network stack uses default priorities
- network stack used for performance measurments: 200, device driver prio: 220
- test application prio: 60
- 100us delay between UDP send invocations
- set system tick length to 10us
- timestamps via ClockCycles() calls
04/28/2010 9:42 AM
post52998
Please keep in mind that we are phasing out the original
devnp-i82544.so driver because it is incredibly difficult
to keep up with the plethora of slightly-different nics
from intel with a home-brewed solution.
Over time, this gap will become more noticeable, esp with
newer nics.
aboyd
Re: RE: RE: Problem: Intel 82567LM doesn't work with jumbo frames
04/30/2010 2:40 AM
post53268
> newer nics.
does this mean that you are going to neglect the broad support of intel nics or rather support only one general device
driver for intel nics (devnp-e1000.so)?
RE: RE: RE: Problem: Intel 82567LM doesn't work with jumbo frames
04/30/2010 7:34 AM
post53279
No, no, no.
> or rather support only one general device driver for intel nics (devnp-e1000.so)?
Yes, yes, yes.
aboyd
