IO-PKT send a packet on startup.
02/15/2010 6:15 AM
post47301
Hey
When I starting io-pkt-v4-hc with my mpc85xx driver.
I see i nicinfo that one packet has been send.
The package is a ARP packet. Is it possible to disable the driver or stack so it's not sending this frame?
I had attached the slogger log.
Re: IO-PKT send a packet on startup.
02/16/2010 8:57 AM
post47364
On 15/02/10 06:15 AM, Lasse Skov wrote:
> Hey
What ARP packet is being sent? Is it a gratuitous ARP?
/P
RE: IO-PKT send a packet on startup.
02/16/2010 9:43 AM
post47379
Almost certainly. I think he wants to turn off
the initial gratuitous ARP when the TCP/IP stack
starts. I'm not sure that's configurable from
the command line.
aboyd
02/16/2010 10:24 AM
post47393
> starts.
There's a gratuitous ARP when the IP address is configured on an interface.
> the command line.
It is not configurable AFAIK.
/P
02/16/2010 10:46 AM
post47402
Hmmmm... okay..
Could i disable this in the io-pkt stack on my own?
And if where?
/LSkov
02/16/2010 10:49 AM
post47404
On 16/02/10 10:46 AM, Lasse Skov wrote:
> Hmmmm... okay..
> And if where?
You should probably look at sys/netinet/if_arp.c arp_ifinit().
At your own risk of course :-)
/P
02/16/2010 11:42 AM
post47419
Thanks...
I see that this arp packet only sendt if the IPAddress is not zero.
So I tried to set the ip to null and now the tsec controller is not send any packages out.
This is good enough for testing my hardware.
If I download hole the core networking and from the foundry, and try to build it i also got a error.
Is there some special things I need to do before i try to build it on my XP machine?
/LSkov
02/16/2010 12:03 PM
post47423
On 16/02/10 11:42 AM, Lasse Skov wrote:
> Thanks...
Ok, great. Yes, as I wrote before "There's a gratuitous ARP when the IP
address is configured on an interface." so if you assign NULL then it
won't be sent.
Have a look at the builds forum for the latest and greatest on that.
Lycka till! ;-)
/P
Re: RE: IO-PKT send a packet on startup.
02/16/2010 10:42 AM
post47400
Are you aware of whether it is possible to disable it somehow?
Another thing is that I can see that some data has been send on both controllers.
This is monitored in nicinfo.
But if I set a computer on the tsec0 controller and monitor the data with a tcpdump I cant monitor anything.
How can this be possible?
Anyone have an idea why this package does not come out through the PHY, and into the contorller?
/LSkov
02/16/2010 10:46 AM
post47401
Not without code changes in the stack.
Or, perhaps some clever default pf rules might work. Just an idea, I
haven't tried it. And maybe pf is not feasible for your situation anyways.
/P
RE: RE: IO-PKT send a packet on startup.
02/16/2010 10:46 AM
post47403
The source to the stack is on the foundry, so if you
want something different than standard ARP, you can
modify it to do whatever you want.
Possibly the link auto-negotiation had not yet completed?
We have seen this before - with DHCP and another driver.
aboyd
Re: RE: RE: IO-PKT send a packet on startup.
02/16/2010 1:24 PM
post47438
I am seeing this on a driver I am currently trying to do, it seems it is related to auto-negotiation not completed. One
thing I am clear is that if the auto-negotiation is not complete, the interface should be in LINK_DOWN state, why the
stack is still sending packets down?
RE: RE: RE: IO-PKT send a packet on startup.
02/16/2010 1:34 PM
post47441
What I was referring to is when the hardware reports
that the link is up - fooling the software - but it
really isn't ... transmissions immediately after the
link up are lost, but if you wait a couple more seconds
after the auto-negotiation has supposedly completed,
then the packets tx works successfully.
aboyd
Re: RE: RE: RE: IO-PKT send a packet on startup.
02/16/2010 3:44 PM
post47452
It's not the hardware reporting the link up,
after I do a 'dhcp.client'
The driver's ioctl call is called, which is a SIOCSIFADDR, and goes to
ether_ioctl call, since the driver is not handerling it. By looking at the ether_ioctl call implementation,
case SIOCSIFADDR:
1684 ifp->if_flags |= IFF_UP;
Then it call the if_init
default:
1713 if ((ifp->if_flags & IFF_RUNNING) == 0)
1714 error = (*ifp->if_init)(ifp);
1715 break;
This is where it flip the IFF_UP bit? Is this expected? At that time of course the Link is not UP. Do I need to do
something extra to explicitly clear the IFF_UP bit in the init call? I've checked few drivers, don't seem to see this
being cleared in init call. Am I miss something?
RE: RE: RE: RE: IO-PKT send a packet on startup.
02/16/2010 3:56 PM
post47456
If you look at the end of any devnp driver _init()
function, you will see it set the IFF_RUNNING flag,
which is how it communicates to the stack that it's
up.
However, given that the PHY has just been reset in
the phy init function just above, that almost certainly
restarts the auto-negotiation which is going to take
2 or 3 seconds to complete.
If you look at the ep93xx driver (which I wrote not
too long ago) I tried to address this in the _start
transmit packet function:
http://svn.ott.qnx.com/view/product/trunk/lib/io-pkt/sys/dev_qnx/ep93xx/
transmit.c?revision=234104&view=markup
If the IFF_RUNNING flag wasn't set, or the NIC_FLAG_LINK_DOWN
bit was set in the (legacy) cfg->flags, no transmission of
packets was attempted - the packet was left queued.
aboyd
02/16/2010 4:00 PM
post47458
There isn't a clear concensus as to whether
or not IFF_RUNNING means the link is up
or not.
> up.
> aboyd
> Networking Drivers
> http://community.qnx.com/sf/go/post47456
02/16/2010 4:08 PM
post47460
> whether or not IFF_RUNNING means the link is up or not.
The if_up utility can get that information with the "-l"
option. Note that all of the devnp (io-pkt) drivers
have bsd_media.c support for link media via ifconfig -v
which uses the driver ioctl to get/set link state.
aboyd
02/17/2010 12:59 PM
post47548
That can help a script to launch the DHCP client only after link is up.
But it doesn't help stack internals (like DAD, see my other email) and
it doesn't help at all if if_up uses routing sockets to implement '-l'
(because routing socket link state may bounce several times, se y other
email).
/P
02/17/2010 1:20 PM
post47560
> > with the "-l" option.
I might mention that the shim supports the
SIOCGIFMEDIA ioctl, hence "ifup -l en0"
should work even with io-net drivers, in
addition to the native devnp io-pkt drivers.
aboyd
02/17/2010 2:28 PM
post47581
AFAIK that state flip/flops together with if_link_state_change().
/P
02/17/2010 2:37 PM
post47582
02/17/2010 3:00 PM
post47583
I am an electrical engineer after all :-)
This isn't what we're talking about here though. We're talking about
auto-negotiation (a protocol) coming to a concluding state and the link
layer informing the stack about it being done (not prematurely doing it
at each state it transitions through along the way).
/P
02/18/2010 4:31 AM
post47626
Hi Guys,
I just cudnt stop myself jumping in :-)
AFAIK, only completing autoneg wouldn't be sufficient in this case.
MAC settings needs to be adjusted according to PHY autonegotiation
results, otherwise MAC and PHY would work in mismatch scenario.
In MPC85XX family (should be the case with others as well), this is
beautifully handled by _speeduplex() functions (One 'd' is missing
here), which are invoked by MDIO library after completing autoneg or
link speed changes.
I think the safest would be to enable transmission of packets from stack
only after this function has been called for the first time.
BR,
Akash Goswami
From: Patrik Lahti [mailto:community-noreply@qnx.com]
Sent: Thursday, February 18, 2010 1:30 AM
To: drivers-networking
Subject: Re: IO-PKT send a packet on startup.
/P
Networking Drivers
http://community.qnx.com/sf/go/post47583
02/18/2010 9:10 AM
post47652
> enable transmission of packets from stack only after
> this (MDI callback) function has been called for the
> first time
If you look at some nicinfo output with the driver
verbose, quite often you will see the link go up,
then down again, then up again.
Your solution would enable tx after the first link
up, which unfortunately would allow tx while the
link was down.
You probably would want to enable tx after the
last link up.
PS This binary up/down behaviour is not to be
referred to as "bouncing" :)
aboyd
02/18/2010 10:30 AM
post47668
On 18/02/10 04:31 AM, Akash Goswami wrote:
> Hi Guys,
Thanks for jumping in :-)
> results,
Just so we're on the same page with terminology. I would include all
that as part the definition of autoneg being "concluded". I.e. the link
is operational - ready - everything has been set up for stack to start
using it.
/P
