Forum Topic - ifconfig stats not getting updated properly: (4 Items)
Hi All,
    I'm working on omapl137 board, after the network driver gets loaded,
If I try to see the stats through the ifconfig -v option, the stats are
not
getting updated properly(input and output both 0 packets).
But if I run the nicinfo, I can see the stats updated correctly.
Actually its an io-net driver, io-pkt-v4 loads it using the devnp-shim,
any idea why this behaviour ? is it the shim layer causing the
problem or with the io-pkt am I missing something,
Thanks in advance.
Here is the sequence:
# io-pkt-v4 -ddm644x-l137 -ptcpip
# ifconfig en0 10.90.74.246/24 up
# ifconfig
en0: flags=80008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,SHIM> mtu
1500
        address: 00:0e:99:02:f9:4e
        inet 10.90.74.246 netmask 0xffffff00 broadcast 10.90.74.255
# ifconfig -v
        input: 0 packets, 0 bytes
        output: 0 packets, 0 bytes
1500
        input: 0 packets, 2661 bytes, 32 multicasts
        output: 0 packets, 42 bytes
# ping -c 3 10.90.74.1
PING 10.90.74.1 (10.90.74.1): 56 data bytes
64 bytes from 10.90.74.1: icmp_seq=0 ttl=255 time=8 ms
64 bytes from 10.90.74.1: icmp_seq=1 ttl=255 time=3 ms
64 bytes from 10.90.74.1: icmp_seq=2 ttl=255 time=3 ms
----10.90.74.1 PING Statistics----
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 3/4/8 ms   variance = 17 ms^2
# ifconfig -v
        input: 6 packets, 306 bytes
        output: 6 packets, 306 bytes
1500
        input: 0 packets, 5094 bytes, 57 multicasts
        output: 0 packets, 378 bytes
# nicinfo
en0:
  TI DM644x EMAC Ethernet Controller
  Physical Node ID ........................... 000E99 02F94E
  Current Physical Node ID ................... 000E99 02F94E
  Current Operation Rate ..................... 100.00 Mb/s half-duplex
  Active Interface Type ...................... MII
    Active PHY address ....................... 1
  Maximum Transmittable data Unit ............ 1514
  Maximum Receivable data Unit ............... 1514
  Hardware Interrupt ......................... 0x22
  Hardware Interrupt ......................... 0x23
  I/O Aperture ............................... 0x1e20000 - 0x1e24fff
  Packets Transmitted OK ..................... 5
  Bytes Transmitted OK ....................... 434
  Broadcast Packets Transmitted OK ........... 2
  Multicast Packets Transmitted OK ........... 0
  Packets Received OK ........................ 80
  Bytes Received OK .......................... 6936
  Broadcast Packets Received OK .............. 76
  Multicast Packets Received OK .............. 0
  Single Collisions on Transmit .............. 0
  Multiple Collisions on Transmit ............ 0
  Deferred Transmits ......................... 0
  Late Collision on Transmit errors .......... 0
  Transmits aborted (excessive collisions) ... 0
  No Carrier on Transmit ..................... 0
  Jabber detected ............................ 0
  Receive Alignment errors ......................
RE: ifconfig stats not getting updated properly
I looked at the source to the shim, and it does the
right thing - it increments the ifp fields.
However, I then did an "svn log" of shim/transmit.c and
sure enough, I see a commit on 2008-12-17 that I fixed
this.
Executive Summary:
1) This was broken.
2) You need a newer shim to fix this.
3) PR 61874 applies.
aboyd
Hi Andrew,
Thanks for all the info,
I tried building the devnp-shim from the trunk,
but its failing, my environment being qnx 6.4.0 for arm.le,
applied the srcversion patch  for QNX 6.4.0 from the link
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/So
urce_Guide
Please find the build error logfile attached.
Ganesh
From: Andrew Boyd [mailto:community-noreply@qnx.com]
Sent: Tuesday, January 05, 2010 8:12 PM
To: drivers-networking
Subject: RE: ifconfig stats not getting updated properly
this.
Executive Summary:
1) This was broken.
aboyd
Networking Drivers
http://community.qnx.com/sf/go/post44568
Attachment: Text qnx640_shim_log.txt 25.39 KB
I have the sinking feeling that changing your
system header files has created more problems
than it solved  :-(
IIRC an easier way to fix the srcversion headache:
#define __SRCVERSION(x)
which I think I put at the end of sys/platform.h
aboyd
