Forum Topic - Is QNX6.4.1 devnp-e1000.so/io-pkt-v4-hc driver supposed to work with this hw:: (7 Items)
Attached archive contains a PDF and pci -vvv.
Would you predict any problem ?
Thanks in advance.
Jeevan
Attachment: Compressed file hw_info.zip 236.62 KB
RE: Is QNX6.4.1 devnp-e1000.so/io-pkt-v4-hc driver supposed to work with this hw:
Both of these device should work fine with the devnp-e1000.so driver.
From: Jeevan Mathew [mailto:community-noreply@qnx.com]
Sent: Tuesday, December 15, 2009 6:41 AM
To: drivers-networking
Subject: Is QNX6.4.1 devnp-e1000.so/io-pkt-v4-hc driver supposed to work
with this hw:
Thanks in advance.
Jeevan
Networking Drivers
http://community.qnx.com/sf/go/post43852
Re: RE: Is QNX6.4.1 devnp-e1000.so/io-pkt-v4-hc driver supposed to work with this hw:
Hello.
This thread is about my hardware, because I have many troubles with that.
If I start my QNX OS normally, then I can see all NIC's if I use ifconfig. (3 NIC's)
But if I put the following commands in my rc.local, then my network isn't comming up:
slay -f io-pkt-v4-hc
io-pkt-v4-hc -de1000 -ptcpip pagesize=8192
After that I don't see any NIC's with ifconfig.
For me it is necessary to use jumbo-frames and all my NIC's support that.
My presumption is that I have problems with my drivers/hardware on the used CPU-Board.
What can I do?
Best regards,
Sven Fieske
RE: RE: Is QNX6.4.1 devnp-e1000.so/io-pkt-v4-hc driver supposed to work with this hw:
Try putting a 'sleep 2' after you slay io-pkt-v4-hc and before starting
the new driver.
From: Sven Fieske [mailto:community-noreply@qnx.com]
Sent: Friday, December 18, 2009 1:55 AM
Subject: Re: RE: Is QNX6.4.1 devnp-e1000.so/io-pkt-v4-hc driver supposed
Hello.
that.
ifconfig. (3 NIC's)
isn't comming up:
that.
used CPU-Board.
What can I do?
Best regards,
Sven Fieske
Networking Drivers
http://community.qnx.com/sf/go/post44099
Re: RE: RE: Is QNX6.4.1 devnp-e1000.so/io-pkt-v4-hc driver supposed to work with this hw:
Works fine, thank you for that.
Now I have a strange effect.
I start my system without any commands in the rc.local and I have only one NIC connected. This I have made for testing.
After start system my active NIC is wm0.
Now I run the rc.local and had apparently a modified mount sequence for the NIC's. ?(
Before running the script wm0 is active, after running wm0 is "Ethernet none" and wm1 is active.
What may be the problem?
RE: RE: RE: Is QNX6.4.1 devnp-e1000.so/io-pkt-v4-hc driver supposed to work with this hw:
The networks only become active once you have performed a dhcp.client or
an ifconfig.
Sent: Friday, December 18, 2009 8:58 AM
Subject: Re: RE: RE: Is QNX6.4.1 devnp-e1000.so/io-pkt-v4-hc driver
the NIC's. ?(
Networking Drivers
http://community.qnx.com/sf/go/post44119
Qnet will also call the interface _init function.
aboyd
