Re: RE: RE: Squelch Test Errors
11/04/2009 11:40 AM
post41328
> > Is there a way I can monitor the status of the rx fifo?
> Not quite sure what you mean. Either the rx fifo
> is overflowing, or it isn't - it's binary. Each
> time the rx fifo overruns, the SQE counter will be
> incremented in the nicinfo for the interface.
I was looking to see if there is a way to monitor the margin to FIFO overrun or maybe this happens so quickley that this
functionality is useless.
Not sure if matters or not but we are using multicast communications.
> Devnp-i82544.so getting out of sync with the link
> over time is a new one on me. When it does, what
> does nicinfo say about the link status? Does it
> think it is up, or down? Is the speed and duplex
> correct? Speaking of that, I hope you aren't using
> the speed and duplex options, which I detest.
I simply swap devnp-e1000.so with devnp-i82544.so in the /etc/system/enum/devices/net file.
I can't recall if nicinfo reported LINK DOWN or not but I can definitely say it reported it was 0 Mbs and communication
from the node was a no go.
> If you start the devnp-i82544.so with the verbose
> option, is there any more interesting information
> in sloginfo when the link gets quiet?
I won't be able to get back to testing this hardware for a few days. I will ensure I start the driver in versbose mode.
> What does the other end says about the link when
> it gets quiet?
I didn't think to check what the remote end was seeing. I will try this when I get the condition to re-occur.
- Richard
