10/20/2009 1:00 AM
post40297
I am using 6.2.1 version of QNX on cPCI platform. The system I am developing is a node (in an IP netwrok) which
directly gets IP data stream from air interface ( radio communication). This IP packet is to be routed by the node to
Internet cloud through a Packet data Gateway.
To do the above routing I intend to employ NAT ing in the Node, which will translate the "Source IP address + Source
Port number" combination to a new port number. The node will re-send the received IP packet after modifying the
Source IP address field in the received packet to that of the IP address of the Node itself and the Source Port
replaced with the newly translated Port Number.
However this needs lower level control of the packet. Normally we use socket programming APIs for IP communication,
which will not be useful here. I have gone through the programmer's manual to some extent but have not been able to
locate the APIs which will allow us to do NAT. Can some one help with inputs on how the above task can be achieved. Are
there APIs available at this level?
Help in this regard will be highly appreciated.
Praveen.
