Forum Topic - devnp-i82544.so from trunk problem:
I download core_networking repository and build x86/devnp-i82544.so from trunk repository.
svn-revision of i82544 folder is 1135.
The size of this build devnp-i82544.so is 62731.
When I try to mount "new" driver:
#io-pkt-v4-hc -v -di82544 verbose
I get:
Unable to init devnp-i82544.so No such device
If I try to use the an "old" devnp-i82544.so ( size 58454 ) from CD installation
/usr/qnx641/target/qnx6/x86/lib/dll/devnp-i82544.so ( size 58454 )  - it work nice.
Whot is the reason of problem?
Re: devnp-i82544.so from trunk problem
On my investigation the problem is in i82544/init.c source:
There is no
pci_attach(0);
call before cickle of pci_find_device() function.
The same problem possible in speedo/detect.c source.
RE: devnp-i82544.so from trunk problem
The pci_attach() is performed by io-pkt, so that it why you have to
perform a complete build.
From: Leonid Khait [mailto:community-noreply@qnx.com]
Sent: Monday, October 12, 2009 3:22 AM
To: drivers-networking
Subject: Re: devnp-i82544.so from trunk problem
There is no
pci_attach(0);
Networking Drivers
http://community.qnx.com/sf/go/post39727
You have to build from the trunk directory so that you build all the
relevant libraries as well. You cannot just build the driver alone. From
the trunk directory perform a "make hinstall" followed by a "make".
Sent: Sunday, October 11, 2009 6:12 AM
Subject: devnp-i82544.so from trunk problem
trunk repository.
I get:
installation
work nice.
Networking Drivers
http://community.qnx.com/sf/go/post39715
Re: RE: devnp-i82544.so from trunk problem
You are right!
After few hours of compiling process by
#make
I get en errors, which stop "make" process.
Then a long time
#make install
work was continued.
Finaly I build speedo driver manually with succsess and without any changes. And this new version resolve mac=XXXXXX
problems.
Fortunally libdrvS.a library was builded ok.
Thank you for Help.
