06/23/2009 1:02 PM
post32342
-Xmx<size_in_mega>
Colin Burgess wrote:
> on linux, how do you tweak the max memory size of the vm?
> Cheers,
> Colin
06/23/2009 1:03 PM
post32343
Same as on windows -Xmx724M
Which would look like for IDE
eclipse/eclipse -vm /usr/lib/jvm/java-6-sun-1.6.0.06/jre/bin/java -vmargs -Xmx724M -XX:MaxPermSize=128m
(the other one another heap size for string objects which sometimes it is running out of)
> Cheers,
> Colin
06/23/2009 1:06 PM
post32344
Command-line argument:
-Xmx<size>
e.g., -Xmx1024M
If this is for an Eclipse-based product, the easiest way to specify this
is by appending this arg on a new line in the ini file (e.g., qde.ini or
eclipse.ini) following the -vmargs line.
HTH,
Christian
> Cheers,
> Colin
