04/24/2009 10:31 AM
post28011
One in a while ( on average once a day ), for no reason that I can see, the IDE becomes unresponsive after a build, to
the point where it doesn't redraw itself. CPU usage is 100%, that last about 30 seconds. To fix this I restart the IDE.
Using the System monitor ( Ubuntu ) I can see lots of instances of
ntox86-addr2line and I think ntox86-c++filt.
Re: Slow down (4.6.0 latest)
04/24/2009 10:33 AM
post28014
Does it ever come back if you don't restart it?
> http://community.qnx.com/sf/go/post28011
RE: Slow down (4.6.0 latest)
04/24/2009 10:35 AM
post28016
> Sent: April-24-09 10:34 AM
> To: general-ide
> Subject: Re: Slow down (4.6.0 latest)
Once it starts to do it, it will do it at every build. I've never been patient enough to wait and see if it ever stops
doing it.
> see, the IDE becomes unresponsive after a build, to the point where it
> > General
> http://community.qnx.com/sf/go/post28014
04/24/2009 10:38 AM
post28017
Do you have Target File System Navigator open when it happens?
>> -----Original Message-----
>> To: general-ide
stops doing it.
>>> General
>> General
> http://community.qnx.com/sf/go/post28016
04/24/2009 2:58 PM
post28067
> Sent: April-24-09 10:39 AM
> To: general-ide
The view is there although it's hidden, I guess that counts as open. I'll close it and see if that makes a difference.
> >> To: general-ide
> been patient enough to wait and see if it ever stops doing it.
> it
> seconds.
> >>> General
> >> General
> > General
> http://community.qnx.com/sf/go/post28017
04/24/2009 3:00 PM
post28068
We just found "ide hanging" bug related to this view. It will be fixed in next update.
>> To: general-ide
04/30/2009 4:42 PM
post28484
With the release candidate the slow down is still there, with the same symptom (I see lots of instances of
ntox86-addr2line and ntox86-c++filt) However now I don't have to exit the IDE to fix the problem. Seen it twice in
about 30 minutes. Always after a build.
> Sent: April-24-09 3:01 PM
> To: general-ide
> in next update.
> >> To: general-ide
> http://community.qnx.com/sf/go/post28068
Re: RE: Slow down (4.6.0 latest)
05/01/2009 8:51 AM
post28494
> IDE to fix the problem. Seen it twice in about 30 minutes. Always after a
> build.
This morning I started the IDE. Create a C++ Folder inside a C++ project (makefile), that was a mistake, I meant to
create a simple folder, the IDE frooze for over a minute. Then after I created a folder and bang, the IDE frooze for
like 45 secondes and again same situation with the ntox86..
05/01/2009 9:41 AM
post28500
Your project does it have lots of binaries inside?
>> build.
> http://community.qnx.com/sf/go/post28494
05/01/2009 9:43 AM
post28502
> Sent: May-01-09 9:42 AM
> To: general-ide
Yes, but why is it doing it only once in a while. Since I made the post close to an hour ago, no problem. Even if there
are lots of binaries I could understand the project taking a long time to build, but it freeze.
> same symptom
> exit the
> after a
> >> build.
> project (makefile), that was a mistake, I meant to create a simple
> folder and bang, the IDE frooze for like 45 secondes and again same
> > General
> http://community.qnx.com/sf/go/post28500
05/01/2009 10:01 AM
post28507
Hi, Mario,
Do you see this slow-down only since adopting a recent interim 4.6.1
build? Do you see the same slow-down with the 4.6.0 IDE or even 4.5.1?
(whichever release you currently have)
The IDE creates this pair of child processes for each binary that needs
to be parsed for any reason, so you would be expected to have many
instances of each. However, they are short-lived ... usually only about
10 seconds.
Does System Monitor show that the IDE process (qde or java) is running
at 100% CPU, or is it maxed out on the addr2line and c++filt processes?
How many C/C++ projects do you have in your workspace? How many
binaries? How many of the projects are QNX projects and how many are
Managed Make projects using the QCC toolchain?
With these numbers, I can try to reproduce your problem to investigate
the cause.
Christian
05/01/2009 10:31 AM
post28517
> From: Christian Damus [mailto:community-noreply@qnx.com]
> Sent: May-01-09 10:01 AM
> To: general-ide
> Subject: RE: Slow down (4.6.0 latest)
> Hi, Mario,
I've seen it with 4.6.0 although at that time Elena though it was related to the Target Navigator. With 4.6 release
candidate the problem is still there.
> about 10 seconds.
Unfortunately I haven't been able to find any pattern into why sometimes it happen and why sometimes it's not.
I'm not 100% sure but I don't think the CPU is maxed out. With all these addr2line and C++filt process running the HD
must be going crazy ;-)
2 are open at this time.
> How many binaries?
62
All Managed Make project
> the cause.
Sometimes it doesn't do it for a whole day ...
> Thanks,
> Christian
> http://community.qnx.com/sf/go/post28507
05/01/2009 1:04 PM
post28529
Thanks, Mario.
I'm trying to reproduce your symptoms with 20 managed-make C++ projects
building 80 binaries (the four standard QNX configurations in each),
without much luck.
I see the following on my system (IDE 4.6 RC, Ubuntu 8.10, 4GB RAM,
Intel Centrino Duo @ 2GHz):
- initial import of the projects into the workspace ties up the UI
thread for at least 10 seconds
-> Eclipse CDT is computing discovery info and other configuration
details on the UI thread, in response to Project Explorer
refresh)
- building all configurations of all projects doesn't make the
workbench
unresponsive
- building doesn't cause any addr2line or c++filt processes to be
spawned
- after build completes, I can expand a bunch of binaries in the
explorer.
This makes the UI unresponsive for 1-2 seconds on each binary, but
this is only while the Project Explorer is waiting for details of
the binary's
contents. Then the UI resumes as normal. Because each
binary-parser
process only lives for about 10 seconds, I don't get more than about
4
of them at any one time while I am expanding binaries
Do you know why so many addr2line and c++filt processes are being
created in your IDE? Are you somehow, unintentionally, triggering
expansion of binaries in the Project Explorer?
Perhaps it has something to do with the number of binaries in each
project. Do you have 31 different managed build configurations in each
project? Or, how did you configure your projects to produce more than
one binary in a single configuration?
Cheers,
Christian
05/01/2009 1:13 PM
post28530
> Sent: May-01-09 1:04 PM
> To: general-ide
> Thanks, Mario.
> without much luck.
There aren't managed make, we use our own makefile. The project consists of a bunch of subdirectories each with a
makefile for which there is make target.
Same except the hardware
> refresh)
> workbench
> unresponsive
For me it's after the build is complete, at least from the makefile point of view. I can see in the console that it's
done with the actual make.
> spawned
Same for me in almost every cases
> explorer.
> the binary's
> contents.
For me that's instantaneous.
> binary-parser
> about
> 4
I wish I knew.
> Are you somehow, unintentionally, triggering expansion of binaries in the Project Explorer?
I always work from the C/C++ Projects view not the project Explorer. I never explain the Binaries "folder". Each
binary exist in two places, the directory the source is in and in a directory call bin that lives at the root of the
project.
If I launch the make target from the root of the project it will builds all 63 executable. But that is not what I do
most of the time, I work on a single program at a time.
> Cheers,
> Christian
> http://community.qnx.com/sf/go/post28529
05/01/2009 1:15 PM
post28531
So it is not CDT Managed project it is Makefile Project?
05/01/2009 1:15 PM
post28532
> Sent: May-01-09 1:15 PM
> To: general-ide
Yes, sorry if I didn't make that clear, sometime I get confuse in all the terminology.
> http://community.qnx.com/sf/go/post28531
05/01/2009 1:18 PM
post28533
What is your host OS?
>> To: general-ide
>> General
> http://community.qnx.com/sf/go/post28532
05/01/2009 1:19 PM
post28534
> Sent: May-01-09 1:18 PM
> To: general-ide
Ubuntu 8.10 64 bit.
> >> To: general-ide
> the terminology.
> >> General
> > General
> http://community.qnx.com/sf/go/post28533
05/01/2009 2:29 PM
post28538
Hi, Mario,
See some replies in-line, below.
Cheers,
Christian
Ah, that makes more sense. I though maybe you were a genius with
Managed Make! ;-)
> > workbench
> > unresponsive
So, perhaps it's the C/C++ Projects view refreshing too aggressively?
Maybe you could try using the Project Explorer, together with the
workbench's Window Working Sets capability to filter out non-C/C++
projects, and see whether that makes a difference?
> > explorer.
> > the binary's
> > contents.
Perhaps because you have debug information in your binaries? The binary
parsers are only invoked when it is absent (such as in the CDT-standard
"Release" configuration). The information is, also, cached until the
next time the binary is built.
> > binary-parser
> > about
> > 4
> I wish I knew.
:-( I guess that's the point of this exercise.
project.
Ah, interesting. I never use the C/C++ Projects view. I see now, that
it actually does a better job of maintaining responsiveness of the
workbench when expanding binaries. It gathers information on a
background thread and shows a "Pending..." item until it is available.
In the meantime, the workbench isn't locked up.
05/04/2009 1:19 PM
post28640
More info today:
I switched from C/C++ project view to Project Explorer to open a closed project, so far so go. Then I disable the Focus
on Active task to see all the projects and it frooze for over 30 seconds with the same symptom. I tried to reproduce
it by switching back and forth between the Project Explorer and C/C++ project, switching Focus on Active Task, but
couldn't reproduce it.
> Sent: May-01-09 2:29 PM
> To: general-ide
> Hi, Mario,
> Cheers,
> Christian
> consists of a bunch of subdirectories each with a makefile for which
> Managed Make! ;-)
> > > workbench
> > > unresponsive
> point of view. I can see in the console that it's done with the actual
> make.
> > > explorer.
> but
> of
> > > the binary's
> > > contents.
> binary
> > > binary-parser
> > > about
> > > 4
> > I wish I knew.
> I never explain the Binaries "folder". Each binary exist in two
> lives at the root of the project.
> each
> > > project? Or, how did you...
05/04/2009 5:10 PM
post28660
Yet more info.
I've close the Project view a few hour agos, no freeze at all. I just activated it and right away the problem showed up
. Seems to be related to the Project Explorer.
05/01/2009 10:01 AM
post28508
Freeze usually means garbage collection... But 30 minutes??? I really don't know but we are investigating now
>> To: general-ide
there are lots of binaries I could understand the project taking a long time to build, but it freeze.
>> same symptom
>> exit the
>> after a
>>>> build.
>>> General
>> General
> http://community.qnx.com/sf/go/post28502
05/01/2009 10:07 AM
post28511
You need dtrace, don't you! :-)
>>> To: general-ide
>>> same symptom
>>> exit the
>>> after a
>>>>> build.
>>>> General
>>> General
>> General
> http://community.qnx.com/sf/go/post28508
cburgess@qnx.com
05/01/2009 10:23 AM
post28513
Java has a lot of good debugging capabilities. Technically if we cannot reproduce it we may ask Mario to enable tracing
for java or for eclipse.
But we try to reproduce it here first.
>>>> To: general-ide
>>>> same symptom
>>>> exit the
>>>> after a
>>>>>> build.
>>>>> General
>>>> General
>>> General
>> General
05/01/2009 10:25 AM
post28515
> Sent: May-01-09 10:24 AM
> To: general-ide
> reproduce it we may ask Mario to enable tracing for java or for
> eclipse.
You read me wrong, it says it happened twice in 30 minutes, but the freeze last between 30 seconds and 60 seconds.
> >>>> To: general-ide
> post close to an hour ago, no problem. Even if there are lots of
> but it freeze.
> the
> >>>> same symptom
> to
> >>>> exit the
> Always
> >>>> after a
> >>>>>> build.
> C++
> same
> >>>>> General
> >>>> General
> >>> General
> >> General
> http://community.qnx.com/sf/go/post28513
