Forum Topic - Application Profiler with C++ code: (3 Items)
I have a process which has 2 threads.  The project is also dependent on several dynamically linked libraries.
Thread 1 receives messages from the system
Thread 2 gets data from Thread 1 via an STL vector acting as a FIFO.
I am trying to use the application profiler to find sections of code that are taking longer to execute than I think they
 should.   I used the system profiler to narrow down the threads I need to look at.
I am having a bit of trouble with the App profiler tool in simple call counting mode.
I can get a list of most of the functions in the thread, but the call graph options are grayed out.
Does the application profiler work with C++ projects?
Should I be able to see the number of calls to functions in the DLLs?
The DLLs are compiled with the -p option and linked with the -lprofilingS options.
This is much more complicated a setup then the example project or what is indicated in the documentation, so I am
wondering if I am missing a step or running into a limitation of the tool.
Thanks for the help.
- Mike
AW: Application Profiler with C++ code
as long as you do not use the function instrumnentation (-finstrument-function),
in "Project Settings" - "Options" -> "Function Instrumentation"
you don't get the information that is needed to do the call graph display.
The classic instrumentation using -p is only a statistical profiling using call counts,
which is not capable of doing call graphs.
/hp
>Von: Michael Cranston [mailto:community-noreply@qnx.com]
>Gesendet: Mittwoch, 22. April 2009 23:22
>An: general-ide
>Betreff: Application Profiler with C++ code
>Hello,
>Thread 1 receives messages from the system Thread 2 gets data
>or what is indicated in the documentation, so I am wondering
>- Mike
>General
>http://community.qnx.com/sf/go/post27833
Re: Application Profiler with C++ code
If all and libs compiled with -finstrument-functions and link with -lprofilingS that means you are doing function
instrumentation and you should run it in Function Instrumentation mode.
If you want call count mode you have to compile it with -p instead (and link with -p). Call Graph is disabled because
you run it in wrong mode...
See http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/IDE4.5ApplicationProfilerTrial for overview
Michael Cranston wrote:
> Hello,
they should.   I used the system profiler to narrow down the threads I need to look at.
> - Mike
