Forum Topic - Linking Managed Projects under IDE 4.6: (2 Items)
I'm using
Version: 4.6.0
Build id: I20090205
I've created a one simple QNX C Project as executable and one as a
static/shared library.
I than use the "convert..." option to convert them to a managed project.
Than I tried to reference a function through the "properties->Project
Dependencies" option in the most simple way but the function was found,
linkage failed.
I also tried filling up the fields under "properties->C/C++
build->Settings->QCC Linker->(-L and -l)"
But those weren't picked up either.
The only thing that enable me to have  workspace with one executable
managed project and a reference library is
using the field "Additional Object Files" in "properties->C/C++
build->Settings->QCC Linker->"
but it just doesn't feel right.
Did I miss something basic?
Lior.
p.s.
Elena, thanks for referring me to IDE 4.6 its what I need to keep me
going as far as using the IDE
Re: Linking Managed Projects under IDE 4.6
These problems have been fixed recently and I hope next integration
build should do what you like to have. Sorry for inconvenience,
Alex
On 26/02/2009 9:07 PM, Lior Keinan wrote:
> Hello,
> I'm using
> Version: 4.6.0
> Build id: I20090205
> linkage failed.
> Thanks,
> Lior.
> p.s.
> http://community.qnx.com/sf/go/post23051
