02/16/2009 6:54 PM
post22323
> From: Colin Burgess [mailto:community-noreply@qnx.com]
> Sent: February-12-09 7:17 PM
> To: general-ide
> Subject: Re: RedHat ( Centos 5 )
> But how did you fail to install the 32bit JVM on Ubuntu? I installed
> it via Synaptic Package Manager.
> I installed the ia32-sun-java6-bin package, and it seemed to be fine?
Yep, it was that simple... My problem came from trying to use Add/Remove option instead of the Synaptic Package Manager
. I`m now up and running with Ubuntu 8.10 64 bit.
The PC is running Vista 64, 4Gig ram with 4 core processor. I`m testing Ubuntu under VMWare, to my amazement the
virtual machine running Ubuntu is faster than the real Vista machine! A compile of a library takes 60 seconds for Vista
, 45 seconds for Ubuntu. Parallel make is setup to use 4 jobs under Vista and 2 jobs under Ubuntu.... Want more? On
Vista I setup the temp folder to be on a ram disk which Ubuntu doesn`t have.
A make clean of an already clean project takes 45 seconds for Vista, 7 for Ubuntu !!!!!
That means I`m better off working from Ubuntu in a virtual machine then real Vista machine. I just can`t wait to see
Ubuntu running on a real machine.
Something is badly broken under Vista. I suspect Cygwin may have something to do with it, on XP doing a make clean takes
15 seconds, faster than Vista, but still twice as slow as the Ubuntu virtual machine!
I`m using a makefile project, I only had to make simple changes to get our build environment to work under Linux.
> Mario Charest wrote:
> > After failling to install a 32bit JVM on Ubuntu, i try Centos5 (
> which the IT guy says is made up of the same binary at RedHat).
> > I manage to install it but got:
> > # An unexpected error has been detected by HotSpot Virtual Machine:
> > # SIGSEGV (0xb) at pc=0xf799f97c, pid=14675, tid=4149266960
> > # Java VM: Java HotSpot(TM) Client VM (1.5.0_11-b03 mixed mode,
> sharing)
> > # Problematic frame:
> > # C [libc.so.6+0x7097c] memcpy+0x1c
> > # An error report file with more information is saved as
> hs_err_pid14675.log
> > # If you would like to submit a bug report, please visit:
> > # http://java.sun.com/webapps/bugreport/crash.jsp
> > /opt/qnx640/host/linux/x86/usr/bin/qde: line 4: 14675 Aborted
> $QNX_HOST/usr/qde/eclipse/qde
> > I guess that's nothing you guys would not something about? I think
> next would by to try RedHat then if that doesn't work I can go after
> someone's head.
> > General
> > http://community.qnx.com/sf/go/post22168
> cburgess@qnx.com
> http://community.qnx.com/sf/go/post22170
