12/17/2008 9:03 AM
post18814
Look like I jumped to conclusion too fast. Further investigation shows that the issue is with PATH. Here is what
happen:
Install 6.3.2
Install 6.4.0
Switch config to 6.3.2
Install ch ( C Shell)
Ch modifies the path variable and add its own directory. Because it was installed after the switch to 6.3.2 the path for
ch ended up at the end of PATH.
When I switched back to 6.4.0 PATH gets modified but the QNX component of the path is not replace, it's first remove and
then the 6.4.0 get added at the end. The results is that the order is changed, resulting in chaos.
After switching to 6.4.0 echo was not the one from the 6.4.0 but rather from ch. I'm even afraid it could be the one
coming windows itself. I guess the solution is to prefix all commands in our makefile with $QNX_HOST
> Mario Charest wrote:
> > With IDE 4.5.0 The echo command under Windows doesn't seems to process \c
> anymore. Instead of not doing a line feed \c is being displayed
> echo.exe is still interpreting escape sequences in 6.4
> C:\>C:/QNX630/host/win32/x86/usr/bin/echo.exe "foo\cbar"
> foo
> C:\>C:/QNX640/host/win32/x86/usr/bin/echo.exe "foo\cbar"
> foo
> C:\>C:/QNX630/host/win32/x86/usr/bin/echo.exe "foo\nbar"
> foo
> bar
> C:\>C:/QNX640/host/win32/x86/usr/bin/echo.exe "foo\nbar"
> foo
> bar
> Regards,
> Ryan Mansfield
