12/02/2008 1:08 PM
post17772
The two red markers only show missing plugin from the feature but do not prevent the feature from loading.
Are you using 6.4.0 as your target baseline? You can check this by going to "Preferences -> QNX" look at the right side
panel the "Select Install:" field.
If the search works but link is not, there could be some old indexes from your previous install. You can try flashing
the doc indexes by removing (or renaming) this directory:
C:\Documents and Settings\<yourID>\momentics\4.5\configuration\org.eclipse.help.base\index
And enter the help again do a search to re-do the indexing.
