Forum Topic - how can I debug the shared library: (7 Items)
I got the following error when debug the program,
Error while reading shared library symbols:
RE: how can I debug the shared library
any text after ":"?
From: zhandong gao [mailto:community-noreply@qnx.com]
Sent: September 25, 2008 12:15 AM
To: general-ide
Subject: how can I debug the shared library
I got the following error when debug the program, Error while reading
General
http://community.qnx.com/sf/go/post13987
Re: RE: how can I debug the shared library
Sorry, here is the whole msg,
libTest_g.so: No such file or directory.
Stopped due to shared library event
> any text after ":"?
> To: general-ide
> Thanks
Re: how can I debug the shared library
You need to set shared library paths for debugger to read symbols. This is not actually an error but you won't be able
to go "in" shared library.
Please see debugger FAQ http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/DebuggerFAQ
>> any text after ":"?
>> -----Original Message-----
>> To: general-ide
>> Thanks
>> General
> http://community.qnx.com/sf/go/post14063
Attachment: Text elaskavaia.vcf 116 bytes
Thank you for your reply, the symbols problem was resolved. I am getting the following problem now,
Warning: /cygdrive/c/ide4-workspace/MyworkingDir/\336\377\377\377\006: No such file or directory.
No source file named Test1.cpp.
No source file named Test2.cpp.
Looks like it can not find the shared library source file, I set the path of of the source file, it has the same problem
>  actually an error but you won't be able to go "in" shared library.
> >> any text after ":"?
> >> To: general-ide
> >> Thanks
> >> General
> > General
The warning you see should not affect debugging. Does you source base contain these two files? If you put breakpoints in
 them does it work?
problem.
>>>> any text after ":"?
>>>> To: general-ide
>>>> Thanks
>>>> General
>>> General
> http://community.qnx.com/sf/go/post14129
I am able to debug the library now. Thank you for your help
> these two files? If you put breakpoints in them does it work?
>  of the source file, it has the same problem.
> not
> projects.
> >>>> any text after ":"?
> >>>> To: general-ide
> >>>> Thanks
> >>>> General
> >>> General
> > General
