Forum Topic - New QNX C++ Project does not respect GCC_VERSION : (8 Items)
first of all, the new IDE 4.5 Tau is a great step forward! I could only suggest everyone to give it try immediately.
Today I've detected a minor difference to IDE 4.0. I've created a new QNX C++ Project. But the following build process
fails because of selecting the old gcc 2.95. The reason is in the following line of the common.mk:
GCC_VERSION:=$($(call EXPRESSION,GCC_VERSION))
This does not extract the given gcc version:
GCC_VERSION=4.2.3
This is the line used for/from IDE 4.0:
GCC_VERSION:=$($(firstword $(foreach a, GCC_VERSION_$(CPUDIR) GCC_VERSION, \
			$(if $($(a)), $(a), ))))
and everything works as expected.
A bit annoying is that e.g. enabling the Debug version, this line is replaced by the old one, again.
Is this a known problem?
Bye
Christian
Re: New QNX C++ Project does not respect GCC_VERSION
Interesting. I testd it on one of the latest builds. Works fine for me.
So, let us to know about your build and which compilers are available on
your host machine. I'd also appreciate console log and whatever you
think can be helpful in this case.
My first thought: you used not the latest build of IDE and worked
against QNX 6.3.2 (not 6.4).  There was a bug  when IDE did not
recognize correctly QNX version  which caused it while building to apply
wrong QNX_INTERNAL block.
Alex.
Christian Leutloff wrote:
> Hello,
> GCC_VERSION=4.2.3
> Bye
> Christian
> http://community.qnx.com/sf/go/post10462
I'm using the latest public build:
eclipse.buildId=I20080516
You are right, I'm using QNX 6.3.0, SP3 with all the patches plus IDE 4.5, plus gcc 4.2.3 (incl. the binutils).
Is there a way to trick the IDE to determine the right version!?
> Regards,
> Alex.
> > Hello,
> + Project. But the following build process fails because of selecting the old
> > GCC_VERSION=4.2.3
> > Bye
> > Christian
> > General
AFAIK, you should expect new build in a few days. It correctly
discriminates version of QNX, I suppose. Stay tune
Alex
>> Regards,
>> Alex.
>>> Hello,
>>> GCC_VERSION=4.2.3
>>> Bye
>>> Christian
>>> General
> http://community.qnx.com/sf/go/post10486
The newer and the latest build are not removing my definition and let most of my definitions in place. Therefore I'm
able to mix editing by hand and using the project properties. This is a huge step forward. Thanks.
But a minor issue remains:
Getting the GCC_VERSION from an included makefile is not supported, e.g. setting the following in defs.mk:
GCC_VERSION=4.2.3
and load this in common.mk:
include path/to/defs.mk
Then the build uses the gcc version 2.95.3 instead of the 4.2.3, the workaround is to define another variable in the
defs.mk, e.g.:
USE_GCC_VERSION=4.2.3
and then put this additional line in each common.mk:
GCC_VERSION=$(USE_GCC_VERSION)
and the build uses 4.2.3 as it is desired.
The IDE 4.5 is a lot better than 4.0. However it can be improved further by supporting the inclusion of additional
makefiles. At the moment the project properties dialog shows that the used gcc is the default one and not the version 4.
2.3. The version 4.2.3 is known to the IDE and it is selectable in the dialog.
I've created a tracker report:
http://community.qnx.com/sf/reporting/do/viewReport/projects.ide/reporting/report1008
Is this usefull?
Christian
argh, okay, it is a *report* for trackers - I wish could edit my last posting ...
There are some macros that could be overridden. But this is not a
limitation, particularly for GCC_VERSION. This one can be defined
     - in common.mk manually or using project properties dialog from IDE.
     - in the file you included into common.mk if you do not have this
setting in common.mk.
The collision can occur just in one case: if you have this macro
definition in included make file and late other definition in common.mk.
The last one could appear there if you either did it manually or
selected in  project properties dialog non-default version of compiler.
Alex.
> http://community.qnx.com/sf/go/post14562
I have retried it with the latest IDE (eclipse.buildId=I20080915).
The build does not honor the definition in the included makefile.
This is the output on the Console:
C:/programme/QNX630/host/win32/x86/usr/bin/qcc -V2.95.3,gcc_ntox86
<---- common.mk begin  --->
# This is an automatically generated record.
# The area between QNX Internal Start and QNX Internal End is controlled by
# the QNX IDE properties.
XI_MKFILES_ROOT=$(CURDIR)/../../../../tools/mk
ifndef QCONFIG
QCONFIG=qconfig.mk
endif
include $(QCONFIG)
ifndef QNX_INTERNAL
QNX_INTERNAL=$(PROJECT_ROOT)/.qnx_internal.mk
endif
include $(XI_MKFILES_ROOT)/xidefs.mk
#===== USEFILE - the file containing the usage message for the application.
USEFILE=
include $(MKFILES_ROOT)/qmacros.mk
include $(QNX_INTERNAL)
include $(MKFILES_ROOT)/qtargets.mk
OPTIMIZE_TYPE=$(OPTIMIZE_TYPE_$(filter g, $(VARIANTS)))
OPTIMIZE_TYPE_g=none
<---- common.mk end --->
<---- xidefs.mk --->
GCC_VERSION=4.2.3
Any ideas where the problem is?
