Re: Can't import existing projects into workspace
06/28/2008 6:15 AM
post9816
When you moved your project folders, did you moved the project metadata (.project, .cproject) files? You need to have
those metadata files to be able to import the projects.
Even if you don't have those metadata files, you still can re-use the project data. Create the same new porject, select
the same name and use the existing project folder. You will have to re-configurate your project if you have specific
settings within them.
