Re: Code Coverage across projects
04/22/2008 9:32 AM
post7162
I would recommend you to try the last integration build. Big changes
were done in 4.5 after the February build.
Alex.
Michael Cranston wrote:
> Hello,
> I am using Momentics 4.01 (QNX 6.3.2) and I am trying to get Code
> Coverage results across 2 projects.
> One project is an executable binary (the test app), and the other
> project is a dynamically shared library.
> The Code Coverage tool seems to complete, but when I go to review the
> results, I get an error and the results line for the test app are
> blank (not even the application name shows up, just the + sign).
> The results for the library do show up, but are low (3.6%) and I know
> it should be higher than that.
> If I put the lib files into the test app project and make one
> executable, then the CC tool works fine.
> I have also tried this with Momentics 4.5 (Feb build), and get the
> same behavior.
> I have attached the log file. Any help is greatly appreciated.
> Thank,
> - Michael
> http://community.qnx.com/sf/go/post7161
04/22/2008 9:36 AM
post7164
BTW, would you have any problems with the last integration build, I'd
appreciate if you send your example to let us analyze the problem
comprehensively
Best regards,
Alex.
> Regards,
> Alex.
>> Hello,
>> same behavior.
>> Thank,
>> - Michael
>> General
