[SVN] SVN connector error. Can't reach my repository.
08/13/2012 10:53 AM
post94785
I'm trying to install Subversive on qnx momentics ide but when I try to add my repository location I have the following
error :
"SVN: '0x00400006: Validate Repository Location' operation finished with error: Selected SVN connector library is not
available or cannot be loaded.
If you selected native JavaHL connector, please check if binaries are available or install and select pure Java
Subversion connector from the plug-in connectors update site.
If connectors already installed then you can change the selected one at: Window->Preferences->Team->SVN->SVN Connector.
Selected SVN connector library is not available or cannot be loaded.
If connectors already installed then you can change the selected one at: Window->Preferences->Team->SVN->SVN Connector."
When I go at Window->Preferences->Team->SVN->SVN Connector, the SVN connector field is empty.
So I tried to install SVN connector but I can't :
" Subversive SVN Connectors will be ignored because it is already installed, and updates are not permitted."
I'm a little lost there ...
By the way I'm more confortable with Subclipse than Subversive. Is it compatible with QNX momentics ide ?
Thanks for the answers.
Arnaud.
