Forum Topic - How to fillter User Class events?: (11 Items)
Customer noticed that he cannot select User Class events at Class Mode logging since there is no corresponding (User)
Tab in Event Filtres.
Is it available to enable/add User Class Events in IDE 4.6 (QNX Momentics 6.4.1) while logging in Class Mode?
Mike
Re: How to fillter User Class events?
> Hello,
>  since there is no corresponding (User) Tab in Event Filtres.
> Regards,
> Mike
This is a procnto-instr and tracelogger feature that was mentioned to be implemented long ago, but is yet not available.
procnto-instr is not capable of applying filters to this class, as it is also not capable of applying dynamic event
filters to USER class.
dynamic event filters are realy missing, whereas "normal" static filters could be seen as not realy necessary. why would
 you insert user events and filter them afterwards on logging?
/hp
>> Hello,
>> Regards,
>> Mike
> it is also not capable of applying dynamic event filters to USER class.
> filters could be seen as not realy necessary. why would you insert
> /hp
> http://community.qnx.com/sf/go/post65746
As workaround I recomended to filter after logging. But the log file
was big enough because of long time of logging. By myself I uses
tracelogger utility (which is Neutrino Host only) and if I want to log
much time I turn off unnessesary event classes (for example, ker calls
and interrupts) by -F options. That gives me user events plus a couple
of remaining classes. I thought IDE goes in the same way but wondered
it was not.
So, in IDE I can get users event only with globally set Fast or Wide
mode in Event Filters Tab. Am I correct?
Mike
> >> Hello,
> logging
> .4.
> >> Regards,
> >> Mike
> > /hp
> > General
> it was not.
> Regards,
> Mike
IDE goes the some way, but it only can provide filters available on tracelogger.
logging in IDE is done through qconn -> tracelogger.
There is no -F for User Class available.
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=/com.qnx.doc.neutrino_utilities/t/tracelogger.html
HTH
/hp
Здравствуйте, Hans-Peter.
Вы писали 3 сентября 2010 г., 11:51:09:
>> >> Hello,
>> logging
>> .4.
>> >> Regards,
>> >> Mike
>> > /hp
>> > _______________________________________________
>> > General
>> it was not.
>> Regards,
>> Mike
> HTH
> /hp
> http://community.qnx.com/sf/go/post65832
You are right. I used tracelogger's -F classes for other classes. Not
for User class. Seems I explained it not clearly above. Let look from
problem side.
Customer runs several programs which genarate user
events. He watns to minimize log size by disabling unnesessary events.
How he could log his user events with minimum other events using IDE?
By tracelogger I goes like follows:
# tracelogger -F1 -F2 -F4 -F5 -F6 -s0
It leaves Process and System classes plus my own user events.
Mike
> >> >> Hello,
> >> logging
> Momentics 6
> >> .4.
> >> >> Regards,
> >> >> Mike
> >> > /hp
> >> > General
> >> it was not.
> >> Regards,
> >> Mike
> tracelogger.
> > HTH
> > /hp
> > General
> problem side.
> Regards,
> Mike
I double checked IDE 4.6.1 and 4.7.0
in both versions you can filter user event class in total, but not event specific.
From dialog "Log Configurations" you can click through all the event class tabs, including "User" class and disable it.
/hp
That is strangely, because I do not have User Class Tab. Please see attachment screenshot.
Attachment: Image event_filtres_tab.PNG 666.12 KB
which Build Id do you use? Help -> About
I have 2010015 running
And which qconn version are you running?
# use -i qconn
DATE=2009/05/20-17:25:15-EDT
> # use -i qconn
I use Version 4.6.0 Build id: I20090510
And qconn DATE=2009/05/20-17:25:15-EDT
It seems my build id is older. How can I update it to your id?
The IDE does not provide the ability to enable/disable user events for kernel logging. There is an open feature request
for adding this functionality, but there is no ETA for its completion.
> Hello,
> Regards,
> Mike
I understood it. The problem of customer is how to get user events in
Class Specific mode of Events Filter of Log Configuration dialog in
6.4.1.
I have just tried QNX Momentics 6.5.0 with IDE Version: 4.7.0 Build
id: 201006232051 and I can get user events in above mentioned mode!
This is a good news. And still a bad one is that customer is 6.4.1 buyer.
I cannot just say to him - go to 6.5.0 :(
Mike
> for kernel logging. There is an open feature request for adding this
>> Hello,
>> Regards,
>> Mike
