Forum Topic - CVS Compare: (3 Items)
CVS Compare
This is probably an Eclipse question more then a QNX one but here goes anyway.
Our source files contains keyword to be expended:
//@ $Source: $
//@ $Date: $
//@ $Revision: $
//@ $Name:  $
When I try to do a compare between the head and a branch for example, EVERY file comes back has having a difference.
Anyway to filter this out somehow?
RE: CVS Compare
There are settings in the preferences to avoid doing the
keyword expansion on checkout and/or to refresh the keywords
before doing the compare.
You might want to try those out.
Hope this helps,
 Thomas
> From: Mario Charest [mailto:mcharest@zinformatic.com]
> Sent: November 28, 2007 3:50 PM
> To: general-ide
> Subject: CVS Compare
> here goes anyway.
> //@ $Source: $
> //@ $Date: $
> //@ $Revision: $
> //@ $Name:  $
> http://community.qnx.com/sf/go/post3069
Re: RE: CVS Compare
That's a no go.  Other tools I use allow some filtering to be specified.  In this perticular case I would instruct the
tool to ignore lines starting with //@.  Just a suggestion ;-)
> Hope this helps,
>  Thomas
> > To: general-ide
> > here goes anyway.
> > //@ $Source: $
> > //@ $Date: $
> > //@ $Revision: $
> > //@ $Name:  $
> > General
