Forum Topic - Automatic Refresh in Target Navigator not working with DNS instead of IP: (1 Item)
I found, that when I setup two targets for the same board, the automatic refresh will only work for the one where I
enter the IP adress directly.
The second one is using the name resolution.
When the target is rebooted, only the target with the IP is reconnecting.
See attached screenshot.
When I restart the IDE, both targets can connect.
I guess that DNS is only done once when starting the IDE.
As far as I can remember this was also the same case for older versions.
I use Version: 4.7.0 Build id: 201005052057 at the moment.
greetings,
Stefan
Attachment: Image AutoRefreshNotWorkingWithDNS.JPG 24.86 KB
