RE: Could not open the editor: the project odes not contain valid configurations
02/12/2010 8:14 AM
post47207
Hi, Kevin,
How did you create the project? What kind of project is it? This error indicates that the .cproject file is messed up:
the IDE cannot load any configurations from it. A QNX C/C++ Project will always have one configuration as the Eclipse
CDT infrastructure sees it; for other project types, you add and remove configurations, yourself. Usually when a
project has only one configuration, it will not allow it to be deleted, so I suspect that something else broke the .
cproject file.
Cheers,
Christian
From: Kevin Stallard [mailto:community-noreply@qnx.com]
Sent: Thu 2/11/2010 7:12 PM
To: general-ide
Subject: Could not open the editor: the project odes not contain valid configurations
When I try to open a header file in a project I get the above message. I've taken a screen shot of the error and
attached it.
I can open .h and .c files in other projects, just not this one. I've deleted the project and the project files on disk
and recreated it.
What else can I do to fix this?
Keivn
General
http://community.qnx.com/sf/go/post47185
