Re: Momentics configuration dir on Win32
02/09/2010 10:05 AM
post46917
Hi Andy,
> To facility this requirement on both Linux and
> Windows hosts - the user's home is chosen.
Indeed it is, yet it defaults to $home/$Application_name equivalent while usually windows applications should store
their settings in "$home/Application Data/$Application_name/" and this is where it comes to problems because the
company's IS solution just maintains the known subdirs (like 'Application Data', 'Favourites', etc) and will ignore
others, like 'momentics'. But you already gave the solution:
> If users have particular requirement to change that configuration data
> directory, they can use the "-configuration" command line option to re-define
> it.
That should work.
Thanks for the help!
bweb
