Forum Topic - Linker Error while building the Neutrino OS/Kernel Source : (3 Items)
We modified the shutdown utility of kernel source, to display our own customized shutdown message.
 We followed the instruction given in the http://community.qnx.com/sf/wiki/do/viewPage/projects.core_os/wiki/
BuildTheOSSource
Steps followed to build,
1.	Created a staging directory for installed binaries and headers to go
% cd /home/kernel
% mkdir stage
2.	Configured the override makefile stub % cd /home/kernel
% cat >qconf-override.mk
USE_INSTALL_ROOT=1
INSTALL_ROOT_nto=/home/kernel/stage
^D
3.	Set the override environment variable to point at the makefile stub
% export QCONF_OVERRIDE=/home/kernel/qconf-override.mk
4.	Installed all the Header Files in the local stage
% cd /home/kernel/trunk
% make OSLIST=nto CPULIST=x86 hinstall
5.	Built the Neutrino OS binaries
% make OSLIST=nto CPULIST=x86 install
But the build stopped with some linker errors as mentioned below.
/home
/kernel/trunk/lib/ncurses/form/nto/x86/a -L /home/kernel/trunk/lib/ncurses/panel/nto/x86/a -L /h
ome/kernel/trunk/lib/ncurses/menu/nto/x86/a -L /home/kernel/trunk/lib/ncurses/ncurses++/nto/x86/
a -L /home/kernel/stage/x86/lib -L /home/kernel/stage/x86/usr/lib -L /usr/qnx641/target/qnx6/x86
/lib -L /usr/qnx641/target/qnx6/x86/usr/lib  -Wl,--rpath-link . -Wl,--rpath-link /home/kernel/tr
unk/lib/ncurses/ncurses/nto/x86/a -Wl,--rpath-link /home/kernel/trunk/lib/ncurses/form/nto/x86/a
 -Wl,--rpath-link /home/kernel/trunk/lib/ncurses/panel/nto/x86/a -Wl,--rpath-link /home/kernel/t
runk/lib/ncurses/menu/nto/x86/a -Wl,--rpath-link /home/kernel/trunk/lib/ncurses/ncurses++/nto/x8
6/a -Wl,--rpath-link /home/kernel/stage/x86/lib -Wl,--rpath-link /home/kernel/stage/x86/usr/lib
-Wl,--rpath-link /usr/qnx641/target/qnx6/x86/lib -Wl,--rpath-link /usr/qnx641/target/qnx6/x86/us
r/lib   -lncurses
/home/kernel/stage/x86/lib/libc.so: undefined reference to `SIGSTACK_CONTEXT'
/home/kernel/stage/x86/lib/libc.so: undefined reference to `SIGSTACK_HANDLER'
/home/kernel/stage/x86/lib/libc.so: undefined reference to `REG_EDI'
/home/kernel/stage/x86/lib/libc.so: undefined reference to `REG_ESI'
/home/kernel/stage/x86/lib/libc.so: undefined reference to `REG_EDX'
/home/kernel/stage/x86/lib/libc.so: undefined reference to `SIGSTACK_SIGNO'
/home/kernel/stage/x86/lib/libc.so: undefined reference to `KER_SIGNAL_RETURN'
/home/kernel/stage/x86/lib/libc.so: undefined reference to `REG_EBP'
/home/kernel/stage/x86/lib/libc.so: undefined reference to `UCONTEXT_CPU'
/home/kernel/stage/x86/lib/libc.so: undefined reference to `REG_ECX'
/home/kernel/stage/x86/lib/libc.so: undefined reference to `REG_EIP'
/home/kernel/stage/x86/lib/libc.so: undefined reference to `REG_EBX'
/home/kernel/stage/x86/lib/libc.so: undefined reference to `REG_ESP'
cc: /usr/qnx641/host/qnx6/x86/usr/bin/ntox86-ld error 1
make[7]: *** [/home/kernel/trunk/lib/ncurses/progs/clear/nto/x86/o/clear] Error 1
make[7]: Leaving directory `/home/kernel/trunk/lib/ncurses/progs/clear/nto/x86/o'
make[6]: *** [install] Error 2
make[6]: Leaving directory `/home/kernel/trunk/lib/ncurses/progs/clear/nto/x86'
make[5]: *** [install] Error 2
make[5]: Leaving directory `/home/kernel/trunk/lib/ncurses/progs/clear/nto'
make[4]: *** [install] Error 2
make[4]: Leaving directory `/home/kernel/trunk/lib/ncurses/progs/clear'
make[3]: *** [install] Error 2
make[3]: Leaving directory `/home/kernel/trunk/lib/ncurses/progs'
make[2]: *** [install] Error 2
make[2]: Leaving directory `/home/kernel/trunk/lib/ncurses'
make[1]: *** [install] Error 2
make[1]: Leaving directory `/home/kernel/trunk/lib'
make: *** [install] Error 2
Please suggest us to resolve this linker error.
Thanks in Advance,
Logesh
Re: Linker Error while building the Neutrino OS/Kernel Source
The libc you built and installed into your stage is no good. It appears
that the assembly that must be preprocessed (.S) is being treated as raw
assembly (.s).  Can you check that file extensions on one of these files
(e.g. /home/kernel/trunk/lib/c/1/x86/sigstub.S)?
Or can you go into /home/kernel/trunk/lib/c/1/x86/so/ and rebuild the
sigstub.o object and post the output from the build?
Ryan Mansfield
Hi Ryan Mansfield,
Thanks for your inputs. It is working fine.
Logesh
