RE: Problem while running application
12/18/2009 1:46 AM
post44098
Hello Vara,
Have you run 'qconn' on the target ? This listens for incoming request from the host-based IDE tools. Once the target
has an IP address, run qconn and it should do what you need. The target needs 'pdebug' too if you want to debug/single
step etc.
You do not say what your target is - is it an X86 machine, or something else ?
What does 'ifconfig' show on the target ?
Does 'sloginfo' show anything ?
Also, what result do you get for 'pidin A' ?
From the host debug side, you need to use the 'IP/qconn' connectivity, not the 'local' option for sure.
You can install QNX Neutrino in Vmware or virtualPC if you want a virtual target (and our tools will work with that just
fine), but there is no other windows/linux simulator, because none is required.
There is extensive documentation on how to set things up for debugging - have you read the docs ?
http://www.qnx.com/developers/docs/6.4.1/ide_en/user_guide/debug.html
Regards
Dave
From: vara prasad pamarthi [mailto:community-noreply@qnx.com]
Sent: Thu 12/17/2009 10:34 PM
To: general-ide
Subject: Problem while running application
I am using QNX development suite IDE 6.4.1 evaluation version.
I built an application as QNX C project and just wrote a printf("hellloworld")
I successfully compiled it..
But Ii don't no how to run the application.
When I am selecting "Run as" -> "C/C++ QNX QConn" nothing is coming up
i tried "Run as" -> "C/C++ Local application" there also nothing is coming up.
I tried running "qconn" , its not giving me any putput
Is there any way to configure the target as simulator or configure the target on the host for running application?
Please help me..
General
http://community.qnx.com/sf/go/post44096
Re: Problem while running application
12/18/2009 3:18 AM
post44101
I Don't have a taget now..
I just want to run simple hello world with out target..
The target I am trying to use is ARM based ( Not yet finalised)..
Kindly help me in this regard..
