12/04/2009 9:42 AM
post43191
> From: Andy Jin [mailto:community-noreply@qnx.com]
> Sent: Thursday, December 03, 2009 9:41 PM
> To: general-ide
> Subject: RE: Open Source Eclipse
> In a nutshell, assuming you have a valid license, you can use the
> Eclipse Galileo with updates from QNX IDE update site. You can get the
> QNX bundles installed to your Eclipse platform.
> However your installation is not identical to the QNX IDE. Because QNX
> IDE is integrated to the QNX Software Development Platform, it works
> seamlessly with the QNX tool chain with all the development
> environments
> pre-configured and fully tested functionalities. You can't get this
> tight integration from your open source eclipse installation.
> There are several features in the QNX IDE that you can't get from the
> update site, e.g. QNX Neutrino documentation bundles.
> So the question is why bothered to do that if you can use the IDE in
> the out of the box QNX Software Development Platform?
Because it`s usually a revision behind. Because some plug-in have trouble installing. Because when you contact plug-in
provider and you mention the QNX bundle they don`t know what you are talking about.
As a matter of fact to "fix" all issue with subversion/subclipse I did just that and all my problem went away.
> Regards,
> Andy
> From: Stefan Nguyen [mailto:community-noreply@qnx.com]
> Sent: Thursday, December 03, 2009 8:48 PM
> To: general-ide
> Subject: Open Source Eclipse
> We've been using QNX Momentics IDE C/C++ and I know it is derived from
> Eclipse.
> My question is can we use Open Source Eclipse Galileo IDE using QNX
> tool
> chain, compilers, debuggers? or do you have QNX IDE plugin for Eclipse
> Galileo?
> Thanks,
> Stefan@taseon
> http://community.qnx.com/sf/go/post43156
> http://community.qnx.com/sf/go/post43158
