Forum Topic - Send file to target: (6 Items)
Send file to target
I am new at qnx and i need help.i use QNX momentics i want to know.
Is there any way to send file to target.i have some config files (*.ini,*.xxx) and i use ftp program to send file but i
want to use Qnx momentics to  send file.
i hope i can explain my problem so thank you  already for your answer.
AW: Send file to target
with QNX Momentitcs you can use "Target File System Navigator" view.
You can find this view from menu Window/Show View/other/QNX Target
To acces your target you need to have "qconn" running on this,
it's the process that talks IDE with.
Within Target File System Navigator, you have to setup your target
using the context menu on left pane of this view.
HTH
>Von: Yakup CENGİZ [mailto:community-noreply@qnx.com]
>Gesendet: Dienstag, 27. Oktober 2009 09:24
>An: general-ide
>Betreff: Send file to target
>Hi,
>General
>http://community.qnx.com/sf/go/post40736
Re: AW: Send file to target
Thank you so much.
Re: Send file to target
Do you mean that you are using the Momentics IDE?  In the System
Information perspective, create a new target project in the Taget
Navigator view to connect to your target system.  Then, open the Target
File System Navigator view (using the "Window -> Show View" menu) and
drag-and-drop your files from your host system onto the target file
system in there.
Make sure that you have the IDE's "qconn" target agent running on your
target system.  See here for details about that:
http://www.qnx.com/developers/docs/6.4.1/ide_en/user_guide/target.html
HTH,
Christian
On Tue, 2009-10-27 at 04:24 -0400, Yakup CENGİZ wrote:
i want to use Qnx momentics to  send file.
Hi Christian,
Yes I am using the Momentics IDE ? I solved my problem and thank you for your detailed  explanation.finally your
suggested link is very useful to solve my question.
You can use Target File System Navigator feature of Momentics to send a file to your target system. Simply,
1.Connect the target with a network cable
2. Get the IP address of the target using "ifconfig" command.
3. Create a target configuration and set the IP address.
4.Now you can see your target systems file system in the navigaor.
Note: To make this work, qconn should be running on the target.
Hope this helps.
