Forum Topic - PtCombobox focus problem:
I am giving focus to a combobox widget using PtGlobalFocusNext() or PtGlobalFocusPrev(). After giving focus i am
retreiving the integer value of the combobox widget using ApName(), but the integer value of combobox widget defined in
abvars.h file is different from what i get using ApName().
Pls suggest how can i get the same integer value for combobox widget.
Re: PtCombobox focus problem
Could you please post a small sample app that shows your problem?
PtWidget_t *CurrentWidget;
//the next focusable widget to ABW_PtLabelName is ABW_CboName
CurrentWidget = PtGlobalFocusNext(ABW_PtLabelName,NULL);
printf("%d,ApName(CurrentWidget));
Here the o/p of printf is different from that of ABN_CboName.
for eg. ABN_CboName = 127, the o/p of ApName(CurrentWidget) = 1283466
This is expected. PtComboBox is a compound widget -- it contains subordinate widgets: PtText, PtList and other
(transient) widgets. Focus is given to the PtText, which doesn't have an ABN number associated with it. Subordinate
widgets of compound widgets are PROCREATED, so add this code after the focus change:
 if( PtWidgetFlags(CurrentWidget) & Pt_PROCREATED ) {
     CurrentWidget = PtWidgetParent( CurrentWidget );
You should get a correct ABN number now.
Thanks Misha
Now code is working fine.
