Forum Topic - Hardware Accelerated PtMTrend widget:
a customer is considering QNX in a project and wants to make sure CPU load is low while some data is being updated in
realtime using the PtMTrend widget.
Which graphics operations need to be accelerated in hardware to ensure the most possible complete acceleration of this
widget?
- Malte
Re: Hardware Accelerated PtMTrend widget
This is a list of PgDraw calls performed by PtMTrend:
 PgDrawGridCx();
 PgDrawIRectCx(); -- filled
 PgDrawPolygonCx();
RE: Hardware Accelerated PtMTrend widget
Hi Malte,
grid:
if line_width > 1, then the "stroke" are polylines, which get converted to spans, which in turn goes to rectangles.
if line_width == 1, then it practically goes straight to rectangles.
irect:
same as above
polygon:
polygon to spans to rectangles
In all these cases, the rectangles are the accelerated "part".  There is possibility on 642 for accelerated polygons,
but most GPUs don't offer this anyhow, so it's a toss up ...
-Derek
From: Misha Nefedov [mailto:community-noreply@qnx.com]
Sent: Thu 23/04/2009 11:14 AM
To: photon-graphics
Subject: Re: Hardware Accelerated PtMTrend widget
 PgDrawGridCx();
 PgDrawPolygonCx();
Photon microGUI
http://community.qnx.com/sf/go/post27902
Attachment: Text winmail.dat 4.24 KB
Re: RE: Hardware Accelerated PtMTrend widget
Thank you, this is helpful. I'm not  sure how you would draw a polygon using rectangles though, or do you mean
rectangles with a height of 1?
Is hardware blitting used to scroll the widget's content to the left?
- Malte
RE: RE: Hardware Accelerated PtMTrend widget
yeah, height of 1...
and yes, blitting is used for the scrolling.
-Derek
From: Malte Mundt [mailto:community-noreply@qnx.com]
Sent: Fri 24/04/2009 4:19 AM
To: photon-graphics
Subject: Re: RE: Hardware Accelerated PtMTrend widget
- Malte
Photon microGUI
http://community.qnx.com/sf/go/post27955
Attachment: Text winmail.dat 3.6 KB
Re: RE: RE: Hardware Accelerated PtMTrend widget
Just curious - a rectangle with the height of 1, seems slower to me than just a horizontal line... no? Or does the
hardware not know about horizontal lines, only about rectangles, and if it's height 1, actually only draws one line
instead of two lines above each other?
- Malte
RE: RE: RE: Hardware Accelerated PtMTrend widget
Most common accelerated primitive ... span vs 1 height is approximately equal ... some h/w did not have a specific "span
" operation ... iirc
 As to if it draws 1 or 2 lines, I think it would depend on the h/w
-Derek
Sent: Fri 24/04/2009 5:11 AM
To: photon-graphics
Subject: Re: RE: RE: Hardware Accelerated PtMTrend widget
- Malte
Photon microGUI
http://community.qnx.com/sf/go/post27960
Attachment: Text winmail.dat 3.75 KB
