unable to initialise io-display
08/23/2019 3:47 AM
post119826
I try to initialize io-display in order to start photon but getting any error
I use pci -v to make sure that the VGA display is present but I am still unable to initialize io-display
What am I doing wrong here? Any suggestions? Thank you
# io-display -dvid=0x8086,did=0x1912
Could not initialize device "vid=0x8086,did=0x1912": No such device
Check 'sloginfo' output for more details
io-display failed to initialise
Class = Display (VGA)
Vendor ID = 8086h, Intel Corporation
Device ID = 1912h, Unknown Unknown
PCI index = 0h
Class Codes = 030000h
Revision ID = 6h
Bus number = 0
Device number = 2
Function num = 0
Status Reg = 10h
Command Reg = 7h
Latency Timer = 0h
Cache Line Size= 10h un-cacheable
BAR - 0 [Mem] = de000000h 64bit length 16777216 enabled
BAR - 2 [Mem] = c0000000h prefetchable 64bit length 268435456 enabled
BAR - 4 [I/O] = f000h length 64 enabled
Subsystem Vendor ID = 8086h
Subsystem ID = 2015h
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = INT A
Interrupt line = 9
CPU Interrupt = 9h
Capabilities Pointer = 40h
Capability ID = 9h - Vendor Specific
Capabilities = 10ch - 62016671h
Capability ID = 10h - PCI Express
Capabilities = 92h - 10008000h
Capability ID = 5h - Message Signaled Interrupts
Capabilities = 0h - 0h
Capability ID = 1h - Power Management
Capabilities = 22h - 0h
Class = System Peripherals (Other)
Device ID = 1911h, Unknown Unknown
PCI index = 0h
Class Codes = 088000h
Revision ID = 0h
Bus number = 0
Device number = 8
Function num = 0
Status Reg = 10h
Command Reg = 6h
Latency Timer = 0h
BAR - 0 [Mem] = df716000h 64bit length 4096 enabled
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = INT A
Interrupt line = 9
CPU Interrupt = 9h
Capabilities Pointer = 90h
Capabilities = 2h - 0h
Capability ID = 13h - Unknown
Capabilities = 306h - 0h
