Re: ApCreateModule Segmentation fault
07/18/2014 9:59 AM
post111106
Hello, Wim.
We are trying to reproduce problem for the moment. If we have additional questions, we'll ask you.
Regards, Renat.
RE: ApCreateModule Segmentation fault
07/21/2014 4:04 AM
post111138
Hi Wim,
this sounds odd enough. First, saving alone will not generate the files that "Generate UI" will. The former will mostly
affect the *.wgt? files in your project's wgt/ directory, whereas the latter creates (or updates) a series of source
files in the src/ directory. Most of those will have names beginning with "ab":
Usemsg
abLfiles
abWfiles
abdefine.h
abevents.h
abimport.h
ablibs.h
ablinks.h
abmain.c
abplatform
abvars.h
abwidgets.h
indLfiles
proto.h
Additionally, this process may create or update source files which were explicitly specified in your widget's callbacks
etc.
You can delete all of the "src/ab*" files to force a re-generation of those upon "Generate UI", but PhAB will never re-
generate or update existing code. E.g., a callback routine already existing in one of your source files will never be
touched by PhAB. Consequently, you might add a pre-build action to your IDE project that could remove all those fully
generated "ab*" files. But again, that will not cover everything.
In theory, the source of your problems could be either the _code_ generated by PhAB, or it could be the widget
definitions (in wgt/*) that are bound into your application by 'phabbind'. Hard to tell which one is the actual culprit.
Can you come up with a reduced test case for this issue? If so, it would be good to have the source - and perhaps the
binary and a core file as well.
Thomas
From: Wim Hellenthal [mailto:community-noreply@qnx.com]
Sent: Donnerstag, 17. Juli 2014 15:27
To: photon-graphics
Subject: ApCreateModule Segmentation fault
Dear all,
I'm having a serious problem with binding the application builder (PhAB) resources. This is what I do
Within the PhAB (as part of the IDE):
- Generate UI
- Save
or the other way around. I assume that both action will generate new resource files (including header files) when
something has changed. Notice that in the error situation nothing actually has changed.
From the IDE
Compile all the source files (the post build binds all the resources into the executable using phabbind).
Now the following happens for some (not all) of the dialogs that are part of the GUI. Whenever I try to create them I
get a segmentation fault. This looks as if there is a mismatch between the generated header files and the position of
the resources in the executable. I can only avoid this type of behaviour when modifying the respective dialog by e.g.
move the button one pixel and then saving the project again from within PhAB. After recompiling the whole project the
dialog will pop-up as expected. But the error will still occur on other dialogs within the project. I can only avoid all
the errors by editing all the dialogs and stuff from within phAB. This is however tedious and error prone. I also does
not give me any confidence that this will always work.
The question is how this can happen and what to do about it. Is there a way to regenerate all the phAB generated files
every time I build the project from within the IDE? More important I don't understand why there is a mismatch in the
first place. Is this because the generated phAB files are corrupt or has it something to do with the phabbind program?
Hope someone can help!
By the way I'm using:
Momentics IDE version 4.7.0
PhAB version version 2.03
Target (x86), version 6.5.0
I'm using a windows 7 machine as host
Best regards,
Wim
Photon microGUI
http://community.qnx.com/sf/go/post111087
To cancel your subscription to this discussion, please e-mail photon-graphics-unsubscribe@community.qnx.com
07/21/2014 5:37 AM
post111139
Dear all,
First of all, thanks for the support.
I think it is not so easy to come up with a reduced test case. The code is proprietary and developed by a third party.
It involves quite a lot of code. I could try to create another project for testing but most likely that code will work
as expected.
I now wonder if it could have something to do with the fact that the complete source was originally designed and build
on a different system. After modifying the resources I can build again and again without any problem running the
executable (at least not the problems I've found so-far) . Note that I came across a related issue where no
segmentation fault occurred but where one of the dialog s did not show up.
Wim
