Forum Topic - Mouse Cursor:
Mouse Cursor
I know that this has got to have a simple solution, but I have been unable to find it via google nor by searching the
QNX websites.
How do you change the mouse cursor to a wait cursor (hour glass) ?
Thank you,
Kendall
RE: Mouse Cursor
Hi Kendall,
you could use the PtWidget resource  Pt_ARG_CURSOR_TYPE :
   PtSetResource( widget, Pt_ARG_CURSOR_TYPE, Ph_CURSOR_LONG_WAIT, 0 );
...or define your own cursor bitmap and use that; see example snippet below.
Cheers,
Thomas
<snip>
	struct bmpcursor_t {
		PhCursorDef_t	cdef;
		char				bmpbuf[ ( HEIGHT1 * BPL1 ) + ( HEIGHT2 * BPL2 ) - 1 ];
	}  bmpcursor;
	char  *bmp = bmpcursor.cdef.images;
	/* Setup first layer description */
	bmpcursor.cdef.size1.x   = WIDTH1;
	bmpcursor.cdef.size1.y   = HEIGHT1;
	bmpcursor.cdef.offset1.x = 0;
	bmpcursor.cdef.offset1.y = 0;
	bmpcursor.cdef.color1    = Pg_BLACK;
	bmpcursor.cdef.bytesperline1 = BPL1;
	/* Setup second layer description */
	bmpcursor.cdef.size2.x   = WIDTH2;
	bmpcursor.cdef.size2.y   = HEIGHT2;
	bmpcursor.cdef.offset2.x = 1;
	bmpcursor.cdef.offset2.y = 3;
	bmpcursor.cdef.color2    = Pg_WHITE;
	bmpcursor.cdef.bytesperline2 = BPL2;
	/* Initialize first layer bitmap */
	bmp[ 0] = bmp[14] = 0xfe;
	bmp[ 1] = bmp[ 2] = bmp[12] = bmp[13] = 0x82;
	bmp[ 3] = bmp[ 4] = bmp[10] = bmp[11] = 0x44;
	bmp[ 5] = bmp[ 6] = bmp[ 8] = bmp[ 9] = 0x28;
	bmp[ 7] = 0x10;
	/* Initialize second layer bitmap */
	bmp = &bmp[15];
	bmp[ 0] = bmp[ 1] = bmp[ 9] = 0x70;
	bmp[ 2] = bmp[ 3] = bmp[ 5] = bmp[ 6] = bmp[ 7] = bmp[ 8] = 0x20;
	bmp[10] = 0xf8;
   PtSetResource( widget, Pt_ARG_BITMAP_CURSOR, &bmpcursor, sizeof bmpcursor );
   PtSetResource( widget, Pt_ARG_CURSOR_TYPE, Ph_CURSOR_BITMAP, 0 );
</snip>
From: Kendall Russell [mailto:community-noreply@qnx.com]
Sent: Mittwoch, 11. Januar 2012 20:48
To: photon-graphics
Subject: Mouse Cursor
QNX websites.
Thank you,
Kendall
Photon microGUI
http://community.qnx.com/sf/go/post90910
Re: RE: Mouse Cursor
Thank you very much.  That is exactly what I was looking for.
