Forum Topic - PtOSContainer failure: (3 Items)
We have a Problem with PtOsContainer. We would like to use PtOSContainer to reduce flickering of widgets we are using in
 our GUI. The size of the PtOSContainer shall be 640x480. But with this size we get a mix of weird pixels, lines and
black areas inside the PtOSContainer. When we reduce the size of the PtOSContainer to about 640x400 pixels, everything
works fine.
Our Hardware is a ATMEL AT91SAM9263.
Do you know what could be the reason for this problem?
Best regards,
Stephen
Re: PtOSContainer failure
Sounds like a driver problem, but hard to tell exactly.
 I would try different pixel depths.
I think so too. I have forwarded this problem to our driver specialist. ^^
Thanks for answer!
