Forum Topic - Phindows detection: (4 Items)
Phindows detection
Anybody knows how an application can detect if it is running under a phindows session?
Re: Phindows detection
One option would be to check for the connection status on TCP port 4868(use netstat utility).
As you know this is the port where phrelay is listening.
If there is a client connected, then your application is for sure relayed.
Thanks for the answer.
But what if your application is running on native photon and there is another application running on phindows? You will
see the phrelay entry of the other application.
I've found that you can use PtQueruSystemInfo and query for the Ph_GCAP_PHINDOWS bit mask in the capabilities member of
the gfx structure that this function fills.
Or maybe Ph_GCAP_RELAY bit
