Forum Topic - Phwindows on embedded device with QNX 6.3.2:
is it possible to connect to an embedded device with Phindows? The hardware is similar to the ATMEL-AT91SAM9263-EK. But
the display does not work yet. The target runs with QNX 6.3.2.
I've found a little tutorial for QNX 6.5.0. Can I use this for QNX 6.3.2 too?
Thanks for your help.
Best regards
Stephen
RE: Phwindows on embedded device with QNX 6.3.2
Give it a whirl, it should be exactly the same or similar.  If you have
any problems with it, post back here.  But basically, you need Photon
environment on the target, and I *think* you need inetd running and an
entry in inetd.conf (as well as a TCPIP/internet connection active).
From: Stephen Sheldon [mailto:community-noreply@qnx.com]
Sent: November 30, 2010 4:34 AM
To: photon-graphics
Subject: Phwindows on embedded device with QNX 6.3.2
hardware is similar to the ATMEL-AT91SAM9263-EK. But the display does
too?
Best regards
Stephen
Photon microGUI
http://community.qnx.com/sf/go/post76400
Re: RE: Phwindows on embedded device with QNX 6.3.2
Yes, you do need to have 'inetd' running and /etc/inetd.conf configured appropriately. Remember you also need 'phrelay'
on the target for the actual communication between you phindows host and the target Photon server.
- Thomas
thanks for your reply!
I stick with the documentation for 6.5.0. Phindows connects to the target and I get the a login screen (see attachment).
 On this login screen I can not see what I write into the text-widgets. When I press the two buttons Phindows closes.
sloginfo prints this message multiple times:
"Jan 01 00:08:25    1     8     0 FontDesc is NULL."
Stephen
Attachment: Image Phindows-Login.JPG 25.43 KB
RE: RE: Phwindows on embedded device with QNX 6.3.2
Is Photon already running on the target, or is this starting a new
instance of Photon?
It is like the $PHOTON_PATH is not being set, or the font server is not
running.
Maybe you can run the font server on the target, something like this:
phfont -d /usr/photon/font_repository -X &
The -X tells it not to exit when there are no clients.
Sent: November 30, 2010 9:57 AM
To: photon-graphics
Subject: Re: RE: Phwindows on embedded device with QNX 6.3.2
target and I get the a login screen (see attachment). On this login
Stephen
Photon microGUI
http://community.qnx.com/sf/go/post76439
Re: RE: RE: Phwindows on embedded device with QNX 6.3.2
We have found the problem. Some fonts were still missing and some files of the font_repository were transfered by FTP in
 ASCII mode instead of binary mode. This has damaged the files.
Thanks for you help!
Best regards,
Stephen
Re: Phwindows on embedded device with QNX 6.3.2
Great!
