Forum Topic - Passing custom options to the io-graphics: (4 Items)
we are using QNX 6.4.x.
The io-display manager is running and I start Photon via ph script.
How can I pass custom options to the io-graphics ?
Should I modify the "ph" file ?
Best regards,
Jacek
RE: Passing custom options to the io-graphics
open /usr/bin/ph
there is a PHGFX envar you can set, it is described in the file.
From: Jacek Rudnicki [mailto:community-noreply@qnx.com]
Sent: Tuesday, August 03, 2010 5:50 AM
To: photon-graphics
Subject: Passing custom options to the io-graphics
Best regards,
Jacek
Photon microGUI
http://community.qnx.com/sf/go/post61373
Re: RE: Passing custom options to the io-graphics
Ok.
One more question.
What is application of the "h" option ?
-h
For HW Wait Idle calls, only wait for the specified video card (default: wait for all cards in use).
What kind of effect can it cause when a multiple displays configuration is used ?
Jacek
RE: RE: Passing custom options to the io-graphics
If you have two cards in the machine, by default, if someone calls
PgWaitHWIdle() each card is stalled out, with the -h option, only the
specified card is stalled out, even if others are in the machine, and
drivers working for them.  Display artifacts can creep in using the -h
option, so I recommend _not_ using it, especially if you are reading
back from the framebuffer on multiple cards.
Sent: Wednesday, August 04, 2010 2:39 AM
To: photon-graphics
Subject: Re: RE: Passing custom options to the io-graphics
Ok.
One more question.
-h
is used ?
Jacek
Photon microGUI
http://community.qnx.com/sf/go/post61511
