Forum Topic - Terminal WIdget: (8 Items)
Terminal WIdget
How we can create a Termina widget inside another widget & that terminal needs to take input from the keyboard?
Re: Terminal WIdget
I am exactly sure what you are asking. Please elaborate...
You can simply create a PtContainer/PtPane in phab, and drop a PtTty or PtTerminal into it.
Re: Terminal WIdget
Not exactly sure ;-)
> PtTerminal into it.
Re: Terminal WIdget
Yes we  created that ( inside PtContainer), but we are unable to get shell
prompt & we cannot give inputs from the keyboard
----- Original Message -----
To: "photon-graphics" <post61027@community.qnx.com>
Sent: Thursday, July 29, 2010 7:06 PM
Subject: Re: Terminal WIdget
> PtTerminal into it.
> Photon microGUI
> http://community.qnx.com/sf/go/post61027
Re: Terminal WIdget
Take a look at these docs:
http://www.qnx.com/developers/docs/6.4.1/photon/widget_ref/pttty.html
look for "Setting PtTty resources" -- it explains what steps should be taken to get your app working. Also it tells why
it may not work in PhAB.
Re: Terminal WIdget
Thanks Misha,
  Using PtTerminal or PtTty we have to do terminal include inside the photon
application.We have tried with the sample code given in the following link
We are able to print some strings on PtTty Widget using
PtTerminalPuts(), but no able to
get keyboard input and execute as command on PtTty Widget. ( as we normally
do on shell)
Our requirement is
     1) We need keyboard input support to PtTerminal or PtTty.
     2) Need to execute command  and print the output on same PtTerminal
or PtTty Widget.
     3) We need to restrict certain command like shutdown from these widget.
Can we get some details or example code where we can able to do above
requirements.
Regards
Praveen
To: "photon-graphics" <post61040@community.qnx.com>
Sent: Thursday, July 29, 2010 7:42 PM
> taken to get your app working. Also it tells why it may not work in PhAB.
> Photon microGUI
> http://community.qnx.com/sf/go/post61040
Re: Terminal WIdget
Sorry, Its working, we had made small mistake wrt argument passing.
Just need your inputs wrt restricting some commands on this shell, may be to
use group related apis right?
To: <post61040@community.qnx.com>
Sent: Friday, July 30, 2010 11:38 AM
> Thanks Misha,
> photon application.We have tried with the sample code given in the
> following link
> normally do on shell)
> Our requirement is
> or PtTty Widget.
> widget.
> requirements.
> Regards
> Praveen
> From: "Misha Nefedov" <community-noreply@qnx.com>
>> Photon microGUI
RE: Terminal WIdget
Make shutdown (or whatever) owned by root, set permissions to 0700, and
start the shell in your terminal as user nobody.
He will not be able to execute shutdown.
Can generalize for other user not just root and can restrict by group if
you need multiple users being able to execute.
  Mate
From: Praveen VS [mailto:community-noreply@qnx.com]
Sent: July 30, 2010 3:37 PM
To: photon-graphics
be to use group related apis right?
> Thanks Misha,
> following link
> Our requirement is
PtTerminal
> or PtTty Widget.
> widget.
> requirements.
> Regards
> Praveen
be
PhAB.
>> Photon microGUI
Photon microGUI
http://community.qnx.com/sf/go/post61154
